10-07-2024 11:48 AM
We recently purchased our first 9800 IP phones, both the 9841 and 9861 models. We've installed the first couple of 9861's and there's some behavior we can't seem to get around. The 9861 will not show the line text label for line #1 when there are any missed calls (see picture) but will instead show the number of missed calls in the line #1 postion. In addtion, when receiving a call, the phone will not display the caller-id of the incoming call unless you press the "return to call" button, which is also showing up in the line #1 postions (see picture).
UCM: 14.0.1.13900-155
Phone load: 3-1-1-0104-37
Solved! Go to Solution.
10-16-2024 06:18 AM
Per my co-worker - the line text label won't appear if there's just the one line on the phone. With just one you'll also get the large clock. I confirmed this by adding a second line, which removes the large clock but the line text labels then appeared.
That would be good to know if there's a way to have the line text label appear with just the one line.
10-07-2024 11:08 PM
As far as I know, that’s normal behavior with the 9800, and I’m unsure if there’s a way to modify it.
Regarding the line showing missed calls, it’s also normal to display notifications like the voicemail notification on that line.
10-08-2024 09:00 AM
I'm having a hard time believing its normal to not be able to see the caller-id unless you first hit the return to call button. That seems very odd to me.
10-16-2024 06:18 AM
10-16-2024 10:25 AM
That did work with respect to line text labels. There is still the issue with caller-id. You have to actually hit the line button in order to display the caller-id information when there is an incoming call. I've unable to find a way around it.
10-16-2024 10:45 AM - edited 10-16-2024 10:46 AM
Ok - I only have a 9841 to test with. I'm kind of surprised it's that way on these new 9800 phones. The 7841s would show the line text with just one line. You must hit the line button on a 9841 phone to see the caller-ID?
I do get caller-id with one or two lines configured on a 9841 without intervention.
10-16-2024 08:58 PM
Does the caller ID not show when you have two lines configured? I haven’t tested a dual line on the 9800, only single lines, and if I remember correctly, that’s the normal behavior.
I’ll test it with the phone in my office and let you know the results.
10-17-2024 06:02 AM
For me caller ID shows for one or two lines on a 9841 phone. But if just one line, just the phone number displays when idle, without the Line Text Label. It sounds like @griffijo's situation is different, meaning no caller ID if more than one line.
04-10-2025 07:19 AM
Our Organization had the same issue and we have found a solution PHONEOS.3-3-1-0002-33.loads is the newest firmware and this resolves the issue
06-06-2025 01:53 PM
That's odd. We still have the issue with our 9841's even after loading up and pushing out PHONEOS.3-3-1-0002-33. Just another item on the list of things we don't like about the 98XX series phones.
