Are you facing this issue with multiple 7912 phones or a single phone. If the issue is with a single phone then it seems to be related to hardware and you can get RMA done for the Phone. If there multiple phones facing the issue, then you can try changing the firmware on them.
Also check the below link , this phone is end of sale and life
http://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/unified-ip-phone-7900-series/prod_end-of-life_notice0900aecd80538042.html
Abhay Reyal
Abhay Singh Reyal
The Only Way To Do Great Work Is To Love What You Do. If You Haven’t Found It Yet, Keep Looking. Don’t Settle
