cdnadmin
Advisor
Advisor
This document was generated from CDN thread
Created by: Adam Chaney on 18-07-2008 06:32:52 PM
Does the JTAPI provider balance the load of device registrations across
all CTI Managers in a cluster?
~Adam
_______________________________________________
Cuae-developers mailing list
Cuae-developers@developer.cisco.com
Attachment not added (content type not allowed): "att1.html"
Subject: Re: [Cuae-developers] JTAPI Question
Replied by: Rajesh Vargheese on 18-07-2008 06:39:24 PM
Adam,
No, the load is not automatically balanced. When you add a devicepool,
you specify your primary and secondary CTI managers. (within your
cluster). When you add a device to a devicepool, it uses the CTI
managers configured for that devicepool.
Rajesh
mailto:cuae-developers-bounces@developer.cisco.com On Behalf Of Adam
Chaney
Sent: Friday, July 18, 2008 1:33 PM
To: cuae-developers@developer.cisco.com
Subject: [Cuae-developers] JTAPI Question
~Adam
Replied by: Adam Chaney on 21-07-2008 02:18:25 PM
We don't know for certain yet, but I ask this to be proactive. I suspect
this is going to be an issue for a current deployment which may need to
balance the load across 4 CTI managers. What repercussions would there
be to adding 4 CallManager clusters - one for each CTI manager - and
distributing the load manually until we can get a fix?
I'll go ahead and open a dev services case now to track.
~Adam
mailto:cuae-developers-bounces@developer.cisco.com On Behalf Of Rajesh
Vargheese (rvarghee)
Sent: Friday, July 18, 2008 1:39 PM
Adam,
Rajesh
Chaney
~Adam
Replied by: Rajesh Vargheese on 21-07-2008 02:50:04 PM
Adam, Even though we do not support load balancing automatically from
cuaeadmin, with 2.5, it is very easy for the developer to get this
functionality since you have access to the management service api. You
can add the load balancing logic in your application and call the apis
to add the devices in the appropriate device pools. ah! the power of
management api....
Rajesh
Sent: Monday, July 21, 2008 9:18 AM
To: Rajesh Vargheese (rvarghee); cuae-developers@developer.cisco.com
Cc: Thad Stoner (tstoner); David Staudt (dstaudt); David Wilson
(dawilso3)
Subject: RE: [Cuae-developers] JTAPI Question
~Adam
Adam,
Rajesh
Chaney
~Adam
Replied by: Adam Chaney on 21-07-2008 04:22:34 PM
Unfortunately, it has to be running in the next few days.
~Adam
From: Rajesh Vargheese (rvarghee) mailto:rvarghee@cisco.com
Sent: Monday, July 21, 2008 9:50 AM
To: Adam Chaney; cuae-developers@developer.cisco.com
(dawilso3)
management api....
Rajesh
(dawilso3)
~Adam
Adam,
Rajesh
Chaney
~Adam
Replied by: Adam Chaney on 21-07-2008 07:44:00 PM
For the benefit of the group, the plan for a deployment like this is to
add all 4 CTI Managers in the one Telephony Server in CUAE. Then create
4 device pools each specifying a different CTI Manager as primary.
It would be nice if CUAE did this for you, but on the other hand maybe
not. In order to optimize the cluster performance, you want to ensure
that the device you're monitoring is on the same subscriber as the CTI
Manager you're registering to. This could be automated with the help of
AXL, but that might be a bit much to ask of the CUAE. As such, the plan
is to be prepared for manual load balancing.
~Adam
(dawilso3)
management api....
Rajesh
(dawilso3)
~Adam
Adam,
Rajesh
Chaney
~Adam
