cdnadmin
Advisor
Advisor
This document was generated from CDN thread
Created by: Chandan Agrawal on 17-08-2010 03:20:18 PM
I have a CUAE deployment. I have two applications, both listening for the TimerFire event. But I have noticed that only one of the scripts get fired wheras the second one doesnt. This is consistent. There is no error in the script that runs.
However if I disable the first application in which the timerfire actually gets fired, the timerfire script of the second application does get fired.
I even tried playing around with the trigger parameters but looks like as if two 'TimerFire's cannot exist on a single deployment.
Is there anyway I can have both the timerfire scripts running? Is this a defect or by design?
Chandan
Subject: RE: Two applications with TimerFire
Replied by: abhishek saxena on 18-08-2010 06:42:39 AM
Hi Chandan
Can you make one script with timerfire event and another with gotRequest and use "AddNonTriggerTimer" API in the gotRequest script.
Please check and let me know as i havnt tried but i think it will work..
ABHISHEK SAXENA
Chandan
Replied by: Rakesh Kumar on 12-09-2010 05:30:18 PM
Hi Chandan,
Can you please attach the appserver traces in verbose mode? This might help in getting to the cause of the two timers not getting triggered.
As of I know, this is not the expected behaviour.
If you can then please attach your application script too.
Rakesh.
Hi Chandan
ABHISHEK SAXENA
Chandan
Replied by: Chandan Agrawal on 15-09-2010 09:55:02 AM
Hi Rakesh,
here are the two applications.
Chandan
Hi Chandan,
Rakesh.
Hi Chandan
ABHISHEK SAXENA
Chandan
Replied by: Nabhonil Sinha on 15-09-2010 01:01:44 PM
Hi Chandan,
Based on the API reference guide, a timer based application can only be triggered using AddTriggerTimer or AddNonTriggerTimer actions
http://developer.cisco.com/static/cuae/8.0/8.0.1/Designer/Metreos.Providers.TimerFacility.TimerFire.html
Nabhonil
