06-19-2019 09:19 AM - edited 06-19-2019 09:20 AM
Hello everyone!
I'm beginner on AXL, and I'm trying to get more information about it. At this moment, i've installed a lab cucm 11.5 to use in this journey.
I've read the documentation on DevNet (developer.cisco.com/site/axl/) but I'm missing something about the return messages in case of success.
I'm using PostMan to send the following command:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/11.5"> <soapenv:Header/> <soapenv:Body> <ns:updateUser> <userid>Test-User1</userid> <pin>12345678</pin> </ns:updateUser> </soapenv:Body> </soapenv:Envelope>
The PIN was successfully changed and I have received a 200 OK and the following content:
<?xml version='1.0' encoding='UTF-8'?> <soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/"> <soapenv:Body> <ns:updateUserResponse xmlns:ns="http://www.cisco.com/AXL/API/10.5"> <return>{String_With_UUID_From_My_Test_USER}</return> </ns:updateUserResponse> </soapenv:Body> </soapenv:Envelope>
But I don't find information on published docs what is the expected return content of the updateUser request.
(ie: User´s UUID is a expected return of updateUser request)
The DevNet documentation indicates the following:
"In general, AXL responses will display/accept UUIDs surrounded by braces and using alpha characters in uppercase:" source: https://developer.cisco.com/docs/axl/#!axl-developer-guide/handling-unique-ids
But where I can find what is the expected response from each kind of request?
TY
Solved! Go to Solution.
06-27-2019 05:16 PM
In general the a AXL schema documentation will be the source for this kind of information.
For example, examining the <updateUserResponse> message:
we can see that <updateUserResponse> is of type axlapi:StandardResponse, which has a child element <return> of type xsd:string, with a pattren restriction of "(true)|(false)|(\{........-....-....-....-............\})"
Many AXL responses re-use the type axlapi:StandardResponse...it looks like it has the possibility of returning 'true' or 'fase', maybe depending on which AXL API is being used.
I frequently use soapUI, which can import the AXL WSDL (the original source code of the AXL schema docs themselves) and auto-generate/execute AXL requests - including templates of the XML with all the various options. You can use this to try out AXL commands and see the actual XML response.
06-27-2019 05:16 PM
