Managing Devices
Share tips on managing device authentication methods. Stay current on device management and learn from our community!
watch here Journey banner_1
 Google will release version 141 on Sept. 30th and this adds a feature to automatically block local LAN access. You can set a flag on your Chrome now to test this. In my testing on multiple PC's, it seems that passport stops auto logging me into Duo ...
doGlooPA by Level 1
  • 768 Views
  • 2 replies
Hello, I am having and issue with a MacBook pro that I am working on setting up DUO 2FA for. This M3 MacBook is running Seqouia version 15.3.2. I am having a weird issue where I set up Duo on it, but it only works when on wi-fi, but the duo push fail...
eortizz by Level 1
  • 646 Views
  • 2 replies
Hi,I have a yubikey in OTP mode that i use as a hardward token.  It is attached to my user account and works fine for Microsoft RDP.I also have a unix login application protected by duo (auto-push disabled). The problem is the only options I am give ...
mikeC2 by Level 1
  • 477 Views
  • 2 replies
 Hello, New Duo customer here, just setting things up and figuring them out. We have our AD integration, test groups and Duo Mobile with Duo for Windows logon working great. I was a little confused about how Duo Desktop works and I think I have found...
doGlooPA by Level 1
  • 970 Views
  • 2 replies
Hi,I configured my hardware token like this: https://duo.com/docs/yubikeyand assigned to user.When launch my rdp session (user+password) can't connect. Yubiko Key doesnt work. Error to etablish connection. I need to do extra configuration?In my rdp c...
omoyano by Level 1
  • 585 Views
  • 1 replies
Hello all, I know in the past (looks like more than a year ago) it was asked if there were any plans for a lock screen prompt. At the time, the answer was no. And it seems that the MacOS guide also mentions that it will not prompt. Are there any pl...
mjwilliams by Level 1
  • 6595 Views
  • 15 replies
  • 3 Helpful votes
Resolved! Apple M1 Support
I know that support on Apple Silicon is currently not available (Two-Factor Authentication for macOS | Duo Security). I know it is probably not possible to say what a projected release date might be, but is anyone aware of an estimate for when we mi...
My organization bought some Duo D-100 tokens for our Duo protected application. I read that the Digipass GO 6 supported "time (TOTP) based (on demand)" algorithms. If we discontinue HOTP support permantely for our protected applications, will our Duo...
Clutz1 by Level 1
  • 924 Views
  • 1 replies
