Issues with ISE Guest Portal Redirection Over WLC When Using Explicit
Carl-in-lux
Hello
We've successfully enabled the ISE Guest Portal on our WLC, and it works well with PCs until we apply explicit proxy settings. After configuring the proxy, the guest portal no longer appears; instead, the PC tries to access the proxy server, bypassing the ISE redirection.
We attempted a workaround by adding our domain (portal.company.com and *.company.com) to the proxy's exceptions list, but the PC continues to prioritize the proxy server.
Any advice on how to ensure the guest portal is accessed before the proxy intervention?
Thanks for your insights.
Carl-in-lux
I finally found the solution to get the redirection to work with the explicit proxy.
i had to add this Microsoft's redirect url in the proxy bypass :
"www.msftconnecttest.com/*"
8 Replies 8
marce1000
              - If the proxy settings are applied on the PC , isn't that normal ?
 M.
-- ' 'Good body every evening' ' this sentence was once spotted on a logo at the entrance of a Weight Watchers Club !
It is normal in a standard situation, but it must be dealt with when using redirection for web authentication.
balaji.bandi
just thinking this use case try  to use WPAD File rather Manually configuring the Proxy, also you can use DHCP Options (if that works).
https://www.cisco.com/c/en/us/td/docs/security/web_security/connector/connector3000/WPADAP.html
or in the browser proxy exception URL add that local domain which you like to directly.
BB
I've done the exception, but i think the actual problem is that ISE redirection is overwritten by the proxy. So the client is never redirect to the ISE Portal. If i type the portal address manually i can get to it.
Does proxy does know how to reach that URL ?
 If i type the portal address manually i can get to it. (using the Proxy settings ?)
This required some troubleshoot and understand the flows - where it dropping ? when the user authenticate, do you see request in Proxy  going to redirect URL ? is this denied or allowed ?
how is your proxy configured for authentication ?
may be check this guide can help you :
https://ciscocustomer.lookbookhq.com/iseguidedjourney/ise-manage-on-my-device-portal
BB
Thank you for providing the link.
It appears to be an issue related to architecture.
Setting up an explicit proxy causes the PC to attempt connection with the proxy server prior to interacting with the ISE Captive Portal, regardless of bypass settings for local and ISE URLs. The PC persists in trying to connect to the proxy server.
However, authentication with the ISE Captive Portal is required before the PC can establish a connection to the proxy server.
A potential solution might be to configure the proxy as a transparent proxy operating at the VLAN level.
Carl-in-lux
This was recent change in Microsoft - as soon as you connect to network, its check with the domain mentioned connect.txt that where all the issue started, once we do the same outlook other stuff start work too.
BB
