Hi,My switch can't connect to the internet - feels isolated and all alone. I got here after a factory reset. Can someone help me fix this? For details, please see the attachment: no_internet.txt
Hello,I have been migrating some company switches from RADIUS to TACACS+ authentication and authorization, and ran into the above error a few times. I could not find, quite literally, any information on this specific error but, I have now found the c...
Hello all,after updating Cisco Prime Infrastructure to version 3.10.5 following critical error appears:PI-Update - Expired Token for the User null (172.16.222.81)Token expired for the stored user in the Account settings page, Please reactivate - Path...
Having a little trouble creating an admin user on one of two Nexus9k's running nx-os 9.2.3. Works fine on one and not the other. I've compared the configs and don't see any difference related to this.When I type the following: username newadminname p...
Hi all, I have to update the config on my Cisco ISE nodes to point their SNMP trap messages to PRTG. Is it possible to send a test SNMP trap to PRTG to confirm that it's working instead of actually triggering an event?
does any one know how to query the 2nd PS state . we use a monitoring tool called auvik and use oid for query. 1.3.6.1.4.1.9.9.13.1.4.1.2 oid is the powersupply state but if i just want the 2nd PS or 2nd switch ( on a stack) power supply states?
Hello Everyone, after an OS-Update from 16.12.4 to 17.12.4 on Catalyst 9300L, we are not able to get the same PRTG-Monitorung results.For Example smart licensing:we have four Sensors setup, but with 17.x we only get response to one Sensor.ciscoSlaEna...
Hi,is there a chance to catch a guru here to help me filter out some very annoying messages on IOS XE SDWAN sw, that happen on console while vManage does some activity? Cisco TAC responded that he knows about "no logging console" only...ESM got on my...
Hi All,I was working with our CCTV provider earlier, he tried to setup their CCTV camera and I can see the MAC of the CCTV on our access switch and I can see the IP address that I allocated for for CCTV on our Core switch. The problem is the CCTV its...
Hello Community Members,I want to reset the SRW224 cisco switch, when I power on the switch the system LED is showing in the green color with stable on the cisco switch end, also I tried to connect over the putty using the serial to Rj45 cable it is ...
Hello,We are having issue on NCS-5504 Platform. It's running on IOS XR Version 7.7.2When we trying to apply policy-map for binds output traffic like following one: interface HundredGigE0/0/2/1.1361service-policy output 2700Mb-OUTWe're facing follow...
HiI am trying to use some eem tcl scripts on 9500-24YA4C IOS XE Software, Version 17.12.04.Scripts trigger syslog messages to email alert but when i read event_reqinfo in tcl, the "msg" filed is missing :event_trigger_num 1 event_id 14 job_id 10 even...
Hi everyone!I am trying to register our organization as an Academy on the Cisco Networking Academy platform. However, I encountered an issue during the registration process.When selecting Azerbaijan – Baku as our location, the “State/Province” field ...
Hi everyone, I recently deployed a new Cisco Catalyst C1300 switch and configured SNMP monitoring (SNMPv2c) using PRTG. I’m able to successfully monitor:Interface trafficDevice uptimeHowever, I’m unable to retrieve data for CPU usage, memory utilizat...
Hello team, I’m having issue with EVE-NG management cloud. I’m using Linux Ubuntu 20.04 as my OS, and VMware Workstation as my hypervisor. I set eve-ng network adapter to be bridged in VMware, then I open EVE-NG web page and create a new lab and add...
Subject | Author | Posted |
04-30-2025 01:37 AM | ||
04-29-2025 04:19 AM | ||
04-15-2025 07:27 AM | ||
04-11-2025 03:49 PM | ||
03-31-2025 02:29 PM |
User | Count |
2 | |
2 | |
1 | |
1 | |
1 |
