07-03-2023 12:08 AM
hi when i add custom cpu sensor for the switch i got no object found
i did try adding OID Value : 1.3.6.1.4.1.9.6.1.101.1.7.0 (worked in cbs350)
and also 1.3.6.1.4.1.9.9.109.1.1.1.1.5.1 (worked on c2960x)
but they did not work
what is the OID Value for the switch CBS220
07-03-2023 02:12 AM
- Could be due to lack of functionality versus the higher model (cbs350) ; check if the OID is available in
https://software.cisco.com/download/home/286327420/type/283965836/release/2.0.2.8
M.
07-03-2023 02:20 AM
i think the functionality is fine because i can find the cpu utilization in the gui interface
07-03-2023 02:45 AM
07-03-2023 07:13 AM
Ditto.
