Program-GUI for Cisco WS-C6509-E product
suleymankutlu
We have a Cisco WS-C6509-E product.We want to use GUI for Cisco WS-C6509-E on Windows 10 Enteprise OS.
Which program can we use?.Can you send us the GUI EXE link?.
Thanks,Regards ...
NOTE:Cisco Network Assistan GUI can not work.Is Cisco Prime LAN Management Solution (LMS) true program?...
Suleyman
------------------ show version ------------------
Cisco IOS Software, s72033_rp Software (s72033_rp-IPBASEK9-M), Version 12.2(33)SXI1, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Sat 28-Mar-09 10:30 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX5, RELEASE SOFTWARE (fc1)
ciscoC6509 uptime is 3 weeks, 17 hours, 50 minutes
Uptime for this control processor is 3 weeks, 17 hours, 52 minutes
Time since ciscoC6509 switched to active is 3 weeks, 17 hours, 51 minutes
System returned to ROM by power cycle at 09:32:04 UTC Tue May 24 2022 (SP by power on)
System image file is "sup-bootdisk:s72033-ipbasek9-mz.122-33.SXI1.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509-E (R7000) processor (revision 1.3) with 983008K/65536K bytes of memory.
Processor board ID SMC11160083
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
2 Virtual Ethernet interfaces
339 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
balaji.bandi
These product is end of life  and you have .bin file that do not have any GUI.
To access generally you need TAR image :
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-6000-series-switches/12012-manage-images-catswitches.html
Cisco Prime Infra also end of Life
what exactly you looking to do with GUI ?
if i  re-call decade back i rigns me belll i used  - CiscoView device manager (not sure that existing any more)
BB
