12-06-2022 09:53 AM
Hello Techies,
I am facing sudden p2p down issue where i have advertised all my ip pools between cisco ASR and juniper router.
Checking the log I found below logs
%IOSXE-5-PLATFORM: F0: cpp_cp: QFP:0.1 Thread:076 TS:00014740836682289247 %PUNT_INJECT-5-DROP_PUNT_CAUSE: punt cause policer drop packet cause 7
I am expecting this as known bug in OS.
Current version: 16.09.02 on cisco asr
Is there any solution to this??
12-07-2022 01:46 AM
I could not find any related bugs. Can you post the output of:
show platform hardware qfp active infrastructure punt config cause 7
12-07-2022 06:26 AM
hi below is output
QFP Punt Table Configuration
Punt table base addr : 0x48848010
punt cause index 7
punt cause name ARP request or response
maximum instances 1
punt table address : 0x4884802C
instance[0] ptr : 0x4884903C
QFP interface handle : 2
Interface name : internal0/0/rp:0
instance address : 0x4884903C
fast failover address : 0x4882D064
Low priority policer : 12
High priority policer : 13
12-07-2022 02:09 AM - edited 12-07-2022 02:13 AM
do this and you will know the reason
12-07-2022 06:25 AM
Hi Below is the output
punt cause index 7
maximum instances 1
If there issue with arp how to find the affected interface then?
Thanks and Regards
12-19-2022 05:05 PM
I am getting a similar log entry on a ISR4331 running 16.12.05... I show the interface in question in the log message for me though
%PUNT_INJECT-5-DROP_PUNT_CAUSE: punt policer drops packets, cause: arp (0x7) from GigabitEthernet0/0/0.401
Not sure why arp is getting punted.. curious as to why
12-20-2022 03:41 AM
hard to find anything on this...I wonder if the policer drops it. Can you post the output of:
#show platform hardware qfp active statistics drop
12-20-2022 03:49 AM
two reason :-
A- you have windows server that send ARP to all host and it hit the ASR
B- you connect to router that use interface instead of next-hop in static route, this lead to router send arp for all IP.
03-27-2024 02:27 AM
I have a similar issue
Mar 27 04:58:34: %IOSXE-5-PLATFORM: R0/0: cpp_cp: QFP:0.0 Thread:000 TS:00004110625087911280 %PUNT_INJECT-5-DROP_PUNT_CAUSE: punt policer drops packets, cause: unknown-encap (0x3) from Vlan1..
Plz advise.
03-27-2024 02:40 AM
Punt table base addr : 0x409A8010
punt cause index 60
punt cause name IP subnet or broadcast packet
maximum instances 1
punt table address : 0x409A8100
instance[0] ptr : 0x409A8D10
instance address : 0x409A8D10
fast failover address : 0x40989864
Low priority policer : 70
High priority policer : 71
03-27-2024 10:40 AM
