10-26-2023 11:12 PM
Hello everyone,
I have added some old cisco switches like 2960-48TT-L to our prime. Now, I am encountering a problem when attempting to activate SNMPv3 for Prime. Typically, I create a group and user configuration as follows:
snmp-server group [group-name] v3 priv write [view] access [access-list]
snmp-server user [username] [group] v3 auth sha [password] priv aes 256 [password]
However, when I apply this configuration to the switches and try to sync them with Prime, SNMP doesn't work as expected. I attempted to troubleshoot the issue by removing certain components. I discovered that the SNMP view was not functioning on these models, so I removed it. Following that, I removed the privacy. This allowed synchronization to occur temporarily, but after a few minutes, it failed again. As a final attempt, I changed the authentication method to use MD5. This allowed synchronization to start, but Prime is now showing a "partial configuration failed" message.
The version of prime that we have is 3.8 and the image on the switches is 12.2(55)SE12.
Does anybody has a solution for that?
Solved! Go to Solution.
10-27-2023 01:21 AM
Hello!
I would upgrade the switches first - try the version 15.0.2. (I know the one you have is the recommended one) I have the same switches with PI 3.10 and they work fine. Does the issue occur on all switches? Have you tried removing the ACL also? Do you have a firewall inbetween?
Also try snmpwalk from another machine.
BR
10-27-2023 01:21 AM
Hello!
BR
10-27-2023 03:27 AM
Hello Daniel,
thank you for your response, next week we will try to update update the prime infrastructure and also the switch. I will let you know if it works.
Best Regards,
Arash
10-27-2023 03:44 AM
I accepted your solution by mistake and I don't know how to reverse the post back. By the I will try to upgrade them next week and hopefully it works fine.
10-27-2023 02:50 AM
- I have a seen various posts concerning buggy snmpv3 support in Cisco Prime , in the past ; you may need to fall back to v2c
M.
10-27-2023 03:34 AM
Hi Marce,
because there is no security on the v2c. I prefer not to activate it in all hardware at all. I will try the update first. Maybe it works.
