SNMPV3 walk is not working with Cisco router running version XR-7.6.2
mailatgk
i am getting issue as below when i do snmpwalk to the node.
[root@k8sc-node1-1 ~]# snmpwalk -v3 -l authPriv -u auto -a md5 -A secureone -x AES128 -X privatetwo 13.20.234.89
SNMPv2-SMI::mib-2 = No more variables left in this MIB View (It is past the end of the MIB tree)
Node config:
RP/0/RP0/CPU0:NCS-1#configure t
Tue Oct 15 14:46:21.634 UTC
RP/0/RP0/CPU0:NCS(config)#snmp-server user auto auto v3 auth md5 secureone priv aes 128 privatetwo
RP/0/RP0/CPU0:NCS(config)#snmp-server group auto v3 priv notify auto read auto
RP/0/RP0/CPU0:NCS(config)#snmp-server community auto RW
Mark Elsen
         - FYI : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuy43949
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
balaji.bandi
You are running latest code that should not be an issue.
what Linux distro you trying SNMP walk ?  Have you tried configured SNMPv2 and see if that works
Once SNMP v2 working, try simple config and see that works
snmp-server user user auto v3 auth md5 “xxxxxxxxx” priv  aes 128 "yyyyyyyyyyyyyy" SystemOwner
BB
Thanks Balaji for your response.
I am trying from below linux version. Yes SNMPV2 is working fine for this router.
[root@s ~]# lsb_release -a
LSB Version: :core-4.1-amd64:core-4.1-noarch
Distributor ID: RedHatEnterprise
Description: Red Hat Enterprise Linux release 8.8 (Ootpa)
Release: 8.8
Codename: Ootpa
Even SNMPV3 walk is working fine with Cisco router running version XRv-6.4.2 from this linux machine. We are facing this issue with other XR version 7.6.2 and 7.11.2.  Not sure where is the problem.
SNMP debug packet at Failing node :
RP/0/RP0/CPU0:cisco_7.11.2#RP/0/RP0/CPU0:Oct 16 19:20:58.791 IST: snmpd[1002]: t9049 Packet received via UDP from 13.49.211.81
RP/0/RP0/CPU0:Oct 16 19:20:58.791 IST: snmpd[1002]: t9049 RECV 64 bytes from 13.49.211.81:63161 to 192.16.6.98, vrfid 0x60000001, tblid 0xe0000001
RP/0/RP0/CPU0:Oct 16 19:20:58.792 IST: snmpd[1002]: t24283 SEND 106 bytes to 13.49.211.81-63161 from 192.16.6.98-161, req_id 2031726168 vrfid 0x60000001, tblid 0xe0000001
RP/0/RP0/CPU0:Oct 16 19:20:58.792 IST: snmpd[1002]: t24283 Packet sent via UDP to 13.49.211.81
RP/0/RP0/CPU0:Oct 16 19:20:58.792 IST: snmpd[1002]: t24283 No of nmsQ with zero element:3 No of nmsQ:3::STOP LOOPING
SNMP debug packet at working node:
RP/0/RP0/CPU0:XRV#RP/0/RP0/CPU0:Oct 16 19:57:52.929 UTC: snmpd[1002]: t7749 Packet received via UDP from 13.49.211.81
RP/0/RP0/CPU0:Oct 16 19:57:52.930 UTC: snmpd[1002]: t7749 RECV 64 bytes from 13.49.211.81:11665 to 101.121.34.107, vrfid 0x60000001, tblid 0xe0000001
RP/0/RP0/CPU0:Oct 16 19:57:52.930 UTC: snmpd[1002]: t7726 SEND 106 bytes to 13.49.211.81-11665 from 101.121.34.107-161, req_id 72343299 vrfid 0x60000001, tblid 0xe0000001
RP/0/RP0/CPU0:Oct 16 19:57:52.930 UTC: snmpd[1002]: t7726 Packet sent via UDP to 13.49.211.81
RP/0/RP0/CPU0:Oct 16 19:57:52.930 UTC: snmpd[1002]: t7726 No of nmsQ with zero element:2 No of nmsQ:2::STOP LOOPING
Tcpdump captured at Linux for failing node :Cisco XRV 7.11.2
We can see that payload is not received from router and only linux is sending the same to node.
[root@~k8sc-node1-1]# tcpdump -i ens3 port 161
dropped privs to tcpdump
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on ens3, link-type EN10MB (Ethernet), capture size 262144 bytes
21:53:38.106074 IP k8sc-node1-1 > 13.49.217.93.snmp:  F=r U="" E= C="" GetRequest(14)
21:53:38.107457 IP 13.49.217.93.snmp > k8sc-node1-1:  F= U="" E=_00_00_00_09_03_00_fa_16_3e_ff_76_94 C="" Report(31)  S:snmpUsmMIB.usmMIBObjects.usmStats.usmStatsUnknownEngineIDs.0=28
21:53:38.107842 IP k8sc-node1-1 > 13.49.217.93.snmp:  F=apr U="auto" [!scoped PDU]68_11_43_46_3a_65_a0_83_ef_0a_a6_1c_93_68_45_84_b2_2a_c1_d5_7d_ca_72_36_46_fc_67_af_0b_0f_a0_66_7f_f8_44_f6_97_a3_17_d9_d9_62_6f_9e_45
21:53:39.108509 IP k8sc-node1-1 > 13.49.217.93.snmp:  F=apr U="auto" [!scoped PDU]2f_59_b5_33_f6_75_22_74_22_c4_ee_d7_e2_39_a6_c6_f3_a7_ce_77_bb_c3_ea_38_c5_72_1f_5b_81_ff_bc_61_29_65_71_3f_51_fe_66_be_f0_69_cc_1f_ec
21:53:40.109497 IP 2311-k8-node1-1.cluster.local.45184 > 13.49.217.93.snmp:  F=apr U="auto" [!scoped PDU]5a_fb_7f_61_2c_33_43_ca_08_42_b1_4c_c0_63_29_7a_a5_19_85_02_09_6b_0c_fe_cf_89_73_49_25_ad_2e_08_05_e4_a9_fc_3b_a7_d9_c8_e1_41_ce_45_34
21:53:40.832765 IP 2311-k8sc-node1-1.cluster.local.8259 > 13.49.217.93.snmp:  F=apr U="auto" [!scoped PDU]a9_05_00_8c_c5_90_92_bb_92_46_1e_a1_59_1e_b5_91_5d_27_6d_c7_d5_04_5b_a0_31_66_ca_c2_b2_89_19_aa_11_4e_d2_19_44_8a_12_4f_84_0c_f6_7b_94_5b_00_22_aa_bd_f9_20
21:53:40.834209 IP 135.249.217.93.snmp > 2311-k8sc-node1-1.cluster.local.8259:  F= U="auto" E=_00_00_00_09_03_00_fa_16_3e_ff_76_94 C="" Report(32)  S:snmpUsmMIB.usmMIBObjects.usmStats.usmStatsWrongDigests.0=9366
21:53:41.110476 IP k8sc-node1-1 > 135.249.217.93.snmp:  F=apr U="auto" [!scoped PDU]62_5f_f7_c2_fc_bc_55_d8_ee_4b_86_44_9e_69_1b_bd_78_3e_0a_67_76_ca_0a_b2_c1_02_af_c0_a8_09_9f_25_20_ae_37_52_66_84_c5_cc_52_1a_7e_d1_68
21:53:42.111818 IP k8sc-node1-1 > 135.249.217.93.snmp:  F=apr U="auto" [!scoped PDU]68_19_09_3e_49_5c_05_95_95_be_32_ac_a3_9d_c2_92_1b_31_87_0c_b0_f1_e5_2a_33_ad_73_15_8a_63_75_8f_16_ed_46_dd_98_77_89_4e_bc_72_5e_51_8a
21:53:43.112511 IP k8sc-node1-1 > 135.249.217.93.snmp:  F=apr U="auto" [!scoped PDU]99_5d_f1_e6_f6_7a_14_ff_3f_78_aa_3c_c1_69_70_15_71_b4_06_97_37_60_ca_4d_d5_26_8e_2f_f6_1f_6f_ea_be_da_b3_10_96_9e_23_00_d4_6b_42_05_c1
Tcpdump captured at Linux for working node: Cisco XRV 6.4.2
We can see payload from both router and Linux here .
[root@2311-k8sc-node1-1 ~]# tcpdump -i ens3 port 161
22:07:59.871608 IP 2311-k8sc-node1-1.cluster.local.38147 > 101.121.34.107.snmp:  F=r U="" E= C="" GetRequest(14)
22:07:59.873813 IP 101.121.34.107.snmp > 2311-k8sc-node1-1.cluster.local.38147:  F= U="" E=_00_00_00_09_03_00_52_54_00_0e_4e_c2 C="" Report(31)  S:snmpUsmMIB.usmMIBObjects.usmStats.usmStatsUnknownEngineIDs.0=5
22:07:59.873969 IP 2311-k8sc-node1-1.cluster.local.38147 > 10.12.34.107.snmp:  F=apr U="auto" [!scoped PDU]33_d6_ba_dc_37_0b_2e_c4_51_a5_45_03_ee_77_a7_12_4e_e2_10_e8_aa_b1_80_c5_f2_8b_aa_f0_34_60_cb_a8_41_d2_a7_9a_b4_d0_2c_1d_2c_a5_13_07_d1
22:07:59.875675 IP 101.121.34.107.snmp > 2311-k8sc-node1-1.cluster.local.38147:  F=ap U="auto" [!scoped PDU]c0_b3_d4_37_cb_b6_c4_4c_25_28_65_aa_60_a7_68_e2_51_42_a6_bf_9c_35_8e_2a_84_40_8c_ae_8e_a0_fc_42_f8_81_80_fa_da_a9_85_3a_45_89_03_c8_51_9f_4f_7c_03_49_18_ec_84_f0_70_aa_be_27_c2_4c_70_57_fd_d9_b0_b4_1d_cd_ce_67_85_2e_46_ca_ab_fd_cc_c8_2e_14_3c_a7_48_a6_c0_e3_e7_36_7d_41_9f_bf_94_0e_fd_8f_e1_54_98_bf_e2_8b_12_84_39_50_09_09_20_19_5b_15_b8_de_99_87_f3_b9_a8_94_9f_4f_4e_43_f5_eb_5c_ac_aa_89_8c_fc_ef_ba_5a_2b_d9_b9_33_df_5a_4e_db_db_e0_d2_c0_b4
22:07:59.875853 IP 2311-k8sc-node1-1.cluster.local.38147 > 101.121.34.107.snmp:  F=apr U="auto" [!scoped PDU]91_01_2d_1d_65_ef_00_66_a2_0f_a1_63_a2_5f_f8_ee_13_01_ed_30_9e_fd_e4_61_99_cb_99_4a_c4_19_e4_c5_52_65_55_63_db_4e_59_e3_05_e4_e6_4b_de_16_bd_db
22:07:59.877164 IP 101.121.34.107.snmp > 2311-k8sc-node1-1.cluster.local.38147:  F=ap U="auto" [!scoped PDU]d4_29_77_37_d1_12_ba_b0_4b_51_65_f2_09_1a_c4_01_eb_3f_8f_ed_84_ed_24_bc_7b_f7_2a_f4_ab_b1_71_2f_c5_38_12_30_95_66_d7_f9_5f_81_94_2f_f9_67_62_4d_82_ab_40_b8_17_68_3d_cd_07
22:07:59.877322 IP 2311-k8sc-node1-1.cluster.local.38147 > 101.121.34.107.snmp:  F=apr U="auto" [!scoped PDU]b1_cf_f6_52_63_65_d3_de_9b_63_3f_8b_87_9f_23_5e_73_68_bb_bb_a0_f5_31_e8_b8_3a_1c_ce_ff_51_76_90_3a_21_ac_15_c7_34_84_aa_08_e2_f3_5f_d2_da_d0_e6
22:07:59.878543 IP 101.121.34.107.snmp > 2311-k8sc-node1-1.cluster.local.38147:  F=ap U="auto" [!scoped PDU]ae_42_2b_81_26_2c_15_c8_3b_b1_11_b9_80_83_3a_75_53_3e_eb_ed_11_71_1c_ee_7b
I am getting timed out.
[root@k8sc-node1-1 ~]# snmpwalk -v3 -l authPriv -u auto -a md5 -A secureone -x AES128 -X privatetwo 13.49.217.93
Timeout: No Response from 13.49.217.93
Hi @balaji.bandi ,
Did you get chance to check on this issue ?
Karuppiah
