Upgrading Supervisor Engine (9400 Series) in Cisco 4500 Series
SalmanZaheerSEC
I have a Cisco Catalyst 4507R+E core switch which is having one faulty Supervisor Engine (WS-X45-SUP8-E).
Since the faulty Sup-Eng is obsolete, the latest available is C9400-SUP-1XL.
I would like to know if the New Sup-Eng is compatible with the Old Switch. If yes, then how can I check the compatibility and what will be the procedure for replacement.
Thanks in advance for Urgent response.
Joseph W. Doherty
Believe it's incompatible.
Leo Laohoo
The 9400 supervisor card will not fit into the 4500 chassis.  Guaranteed.
