Cisco Firepower FPR1120 - Ping does not work from outside to inside
Patts
I'm trying to test the connectivity on my current network setup on the FPP1120 device. But cannot make a successful ping from outside to inside host (inside to outside is working fine). I'm just wondering if ICMP is blocked by default from outside to inside. But I can see the ICMP inspection was enable. NAT and policy rules are already created. Let me know if anyone can share the basic configuration in FDM to enable this access.
Pat
@Patts create a new NAT rule that does not translate the traffic behind the interface, as per your current rule.
See task 3 in this example
https://www.cisco.com/c/en/us/support/docs/security/firepower-management-center/212702-configure-and-verify-nat-on-ftd.html#anc9
9 Replies 9
@Patts Everything from outside to inside would be blocked as default, you have to explictly permit inbound traffic. Run packet-tracer to simulate the traffic flow and provide the output for review, this should indicate whether if your NAT and ACP rules are the problem.
Hi Rob, below is my result. Thanks in advanced.
> packet-tracer input INSIDE icmp 10.2.1.1 8 0 10.64.1.100
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
MAC Access list
Phase: 2
Type: ROUTE-LOOKUP
Subtype: No ECMP load balancing
Result: ALLOW
Config:
Destination is locally connected. No ECMP load balancing.
Found next-hop 10.64.1.100 using egress ifc  data(vrfid:0)
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group NGFW_ONBOX_ACL global
access-list NGFW_ONBOX_ACL advanced permit object-group |acSvcg-268435471 object any-ipv4 object TESTPC rule-id 268435471
access-list NGFW_ONBOX_ACL remark rule-id 268435471: ACCESS POLICY: NGFW_Access_Policy
access-list NGFW_ONBOX_ACL remark rule-id 268435471: L5 RULE: Allow_Outside_To_Inside
object-group service |acSvcg-268435471
 service-object ip
 This packet will be sent to snort for additional processing where a verdict will be reached
Phase: 4
Type: NAT
Subtype: per-session
Result: ALLOW
Config:
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 6
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
class-map inspection_default
 match default-inspection-traffic
policy-map global_policy
 class inspection_default
  inspect icmp
service-policy global_policy global
Phase: 7
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
Phase: 8
Type: NAT
Result: ALLOW
Config:
Phase: 9
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 10
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 300233, packet dispatched to next module
Phase: 11
Type: EXTERNAL-INSPECT
Subtype:
Result: ALLOW
Config:
Application: 'SNORT Inspect'
Phase: 12
Type: SNORT
Subtype:
Result: ALLOW
Config:
Snort Trace:
Packet: ICMP
Session: new snort session
Firewall: allow rule, id 268435471, allow
Snort id 1, NAP id 1, IPS id 0, Verdict PASS
Snort Verdict: (pass-packet) allow this packet
Phase: 13
Type: INPUT-ROUTE-LOOKUP-FROM-OUTPUT-ROUTE-LOOKUP
Subtype: Resolve Preferred Egress interface
Result: ALLOW
Config:
Phase: 14
Type: ADJACENCY-LOOKUP
Subtype: Resolve Nexthop IP address to MAC
Result: ALLOW
Config:
Found adjacency entry for Next-hop 10.64.1.100 on interface  data
Adjacency :Active
MAC address 54ee.7521.4c75 hits 73 reference 1
Result:
input-interface: inside(vrfid:0)
input-status: up
input-line-status: up
output-interface: data(vrfid:0)
output-status: up
output-line-status: up
Action: allow
Hi Rob, below is the capture result.
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
MAC Access list
Phase: 2
Type: ROUTE-LOOKUP
Result: ALLOW
Config:
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
service-object ip
Phase: 4
Type: NAT
Result: ALLOW
Config:
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 6
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
inspect icmp
Phase: 7
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
Phase: 8
Type: NAT
Result: ALLOW
Config:
Phase: 9
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 10
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
Phase: 11
Subtype:
Result: ALLOW
Config:
Phase: 12
Type: SNORT
Subtype:
Result: ALLOW
Config:
Snort Trace:
Packet: ICMP
Phase: 13
Result: ALLOW
Config:
Phase: 14
Result: ALLOW
Config:
Adjacency :Active
Result:
input-status: up
output-status: up
Action: allow
@Patts you've run that packet-tracer from source "inside", you would need to run that from "outside" if you are having a problem communication from outside to inside and want to simulate the traffic flow.
I assume your "outside" interface is called "data"?
Hi Rob, thanks for the quick reply. please check below. Btw, data is my inside interface subnet for the host 10.64.1.100
> packet-tracer input OUTSIDE icmp 10.2.1.1 8 0 10.64.1.100
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
MAC Access list
Phase: 2
Type: ROUTE-LOOKUP
Result: ALLOW
Config:
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-list NGFW_ONBOX_ACL advanced permit object-group |acSvcg-268435471 ifc outside object any-ipv4 ifc data object TESTPC rule-id 268435471
service-object ip
Phase: 4
Type: NAT
Result: ALLOW
Config:
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 6
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
inspect icmp
Phase: 7
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
Phase: 8
Type: NAT
Subtype: rpf-check
Result: DROP
Config:
nat (data,outside) source dynamic 10.64.1.0_24 interface
Result:
input-interface: outside(vrfid:0)
input-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule, Drop-location: frame 0x000055a8dd5243b6 flow (nat-rpf-failed)/snp_sp_action_cb:1140
@Patts NAT is the problem.
Type: NAT
Subtype: rpf-check
Result: DROP
Config:
Create an NAT exemption rule between the source and destination networks to ensure traffic is not unintentially translated.
Sorry Rob, you mean no create a new ACP or just update my NAT? Any sample you can provide? Cheers!
Thanks Rob.
Now its perfectly working.
Super!!
