05-16-2024 01:44 AM
Hi Community,
We have one cisco fpr3105, in which from fxos we are unable to connect to ASA mode. There are only 2 options available which are ftd & local-mgmt. Is there any firmware upgrade require or any different process?
Solved! Go to Solution.
05-16-2024 03:38 AM
Official guide is here: https://www.cisco.com/c/en/us/td/docs/security/firepower/quick_start/reimage/asa-ftd-reimage.html
To be honest, I didn't read it so unsure how helpful it is.
05-16-2024 06:44 AM - edited 05-17-2024 06:07 AM
"connect asa" only works of the device is running the ASA image. Since you are only offered the "connect ftd" option, then your device is running FTD.
What are you trying to do from the cli that you want to connect this way? Whether the device runs ASA or FTD image, those images would be configured with their own unique management address (distinct from the chassis management) that you would use for direct connection.
05-16-2024 02:32 AM
Probably this device runs FTD and not ASA? If you need ASA, you need to reimage the device.
05-16-2024 03:19 AM
How can we do that? Any specific process or similar to ASA firmware upgradation?
05-16-2024 03:38 AM
05-17-2024 06:06 AM
Yes, This URL is helpful & able to re-image from FTD to ASA. Thanks.
05-16-2024 02:53 AM - edited 05-16-2024 03:13 AM
MHM
