- Subscribe to RSS Feed
- Mark as New
- Mark as Read
- Bookmark
- Subscribe
- Printer Friendly Page
11-18-2012 07:38 AM - edited 08-29-2017 10:32 AM
Introduction:
The EEM(Embedded Event manager is a software component of cisco IOS, XR, and NX-OS makes life easier for administrators by tracking and classifying events that take place on a router and providing notification options for those events. EEM allows you to automate tasks, perform minor enhancements and create workarounds.
There are two independent pieces: Applets and Scripting
-> Applets are a collection of CLI commands
-> Scripts are actions coded up in TCL(interpreter language)
EEM uses event detectors and actions to provide notifications of those events:
EEM detectors can be:
1) SNMP:-Monitoring SNMP objects.
2) Syslog:-Responds to various syslog messages, allowing for matching on regular expressions.
3) Counter: Monitoring and responding to interface counter when cross threshold settings.
4) CLI events: Screening CLI input for a regular expression match.
5) None: This event detector is use to test EEM script/applet using "event manager run" command.
6) Timers :(Countdown, watchdog and CRON)
7) IP SLA and Netflows events.
Common regular expressions:
^ = Start of string
$ = End of string
. = Any single character
* = Zero or more instances
+ = One or more instance
? = Zero or one instance
EEM Actions can be:
1)Sending a email messages
2)Executing a cisco command.
3)Generating SNMP traps
4)Reloading the router
5)Generating priotized syslog messages
6)Switching to a secondary processor in a redundant platform
7)requesting system information when an event occurs(like sh tech,sh proccess cpu history).
Sample EEM Scripts:
A) Syslog Event detector:
This example shows the syslog event detector. When the ISP1 interface has been shutdown, the below applet run to turn on the interface and send the alert to the below mention mail id with logged in users information.
Configuration:
event manager applet interface_Shutdown
event syslog pattern "Interface FastEthernet1/0, changed state to administratively down"
action 1.0 cli command "enable"
action 1.5 cli command "config t"
action 2.0 cli command "interface fa1/0"
action 2.5 cli command "no shutdown"
action 3.0 cli command "end"
action 3.5 cli command "who"
action 4.0 mail server "192.168.1.1" to ".engineer@cisco.com." from ".EEM@cisco.com." subject ".ISP1_Interface_fa1/0_SHUT." body "Current users $_cli_result"
Enabling debug detector to get closer view and shutdown the interface fa1/0.
R1#debug event manager action cli
Debug EEM action cli debugging is on
R1#conf tEnter configuration commands, one per line. End with CNTL/Z.R1(config-if)#int fa1/0
R1(config-if)#sh
*Nov 17 23:06:24.215: %LINK-5-CHANGED: Interface FastEthernet1/0, changed state to administratively down
*Nov 17 23:06:24.283: %HA_EM-6-LOG: interface_Shutdown : DEBUG(cli_lib) : : CTL : cli_open called.
*Nov 17 23:06:24.295: %HA_EM-6-LOG: interface_Shutdown : DEBUG(cli_lib) : : OUT : R1>
*Nov 17 23:06:24.299: %HA_EM-6-LOG: interface_Shutdown : DEBUG(cli_lib) : : IN : R1>enable
*Nov 17 23:06:24.319: %HA_EM-6-LOG: interface_Shutdown : DEBUG(cli_lib) : : OUT : R1#
*Nov 17 23:06:24.319: %HA_EM-6-LOG: interface_Shutdown : DEBUG(cli_lib) : : IN : R1#config t
*Nov 17 23:06:24.343: %HA_EM-6-LOG: interface_Shutdown : DEBUG(cli_lib) : : OUT : Enter configuration commands, one per line. End with CNTL/Z.
R1(config-if)#
*Nov 17 23:06:24.347: %HA_EM-6-LOG: interface_Shutdown : DEBUG(cli_lib) : : OUT : R1(config)#
*Nov 17 23:06:24.347: %HA_EM-6-LOG: interface_Shutdown : DEBUG(cli_lib) : : IN : R1(config)#interface fa1/0
*Nov 17 23:06:24.467: %HA_EM-6-LOG: interface_Shutdown : DEBUG(cli_lib) : : OUT : R1(config-if)#
*Nov 17 23:06:24.467: %HA_EM-6-LOG: interface_Shutdown : DEBUG(cli_lib) : : IN : R1(config-if)#no shutdown
*Nov 17 23:06:24.587: %HA_EM-6-LOG: interface_Shutdown : DEBUG(cli_lib) : : OUT : R1(config-if)#
*Nov 17 23:06:24.587: %HA_EM-6-LOG: interface_Shutdown : DEBUG(cli_lib) : : IN : R1(config-if)#end
*Nov 17 23:06:24.643: %SYS-5-CONFIG_I: Configured from console by on vty0 (EEM:interface_Shutdown)
*Nov 17 23:06:24.655: %HA_EM-6-LOG: interface_Shutdown : DEBUG(cli_lib) : : OUT : R1#
*Nov 17 23:06:24.655: %HA_EM-6-LOG: interface_Shutdown : DEBUG(cli_lib) : : IN : R1#who
*Nov 17 23:06:24.727: %HA_EM-6-LOG: interface_Shutdown : DEBUG(cli_lib) : : OUT : Line User
R1(config-if)#Host(s) Idle Location
*Nov 17 23:06:24.731: %HA_EM-6-LOG: interface_Shutdown : DEBUG(cli_lib) : : OUT : 0 con 0 idle 00:00:02
*Nov 17 23:06:24.731: %HA_EM-6-LOG: interface_Shutdown : DEBUG(cli_lib) : : OUT : * 2 vty 0 idle 00:00:00 EEM:interface_Shutdown
*Nov 17 23:06:24.735: %HA_EM-6-LOG: interface_Shutdown : DEBUG(cli_lib) : : OUT :
*Nov 17 23:06:24.735: %HA_EM-6-LOG: interface_Shutdown : DEBUG(cli_lib) : : OUT : Interface User Mode Idle Peer Address
*Nov 17 23:06:24.739: %HA_EM-6-LOG: interface_Shutdown : DEBUG(cli_lib) : : OUT : R1#
R1(config-if)#
*Nov 17 23:06:26.487: %LINK-3-UPDOWN: Interface FastEthernet1/0, changed state to up
B) CLI Event detector:
In this example applet has created to stop "debugging" command on the CLI. If anyone enter the debug command it will have no effect, also clock and user’s information will be stored in flash.
Configuration:
event manager applet Stop_Debug
event cli pattern "debug" sync no skip yes
action 2.0 cli command "sh users | append flash:Debug"
action 3.0 cli command "sh clock | append flash:Debug_clock"
Verification:
Checking the registered applet with following command:
R1#sh event manager policy registered
No. Class Type Event Type Trap Time Registered Name
1 applet user cli Off Fri Mar 1 00:08:05 2002 Stop_Debug
pattern {debug} sync no skip yes
maxrun 20.000
R1#debug all
R1#sh debugging......(Not showing any debug running on device)
R1#sh flash:
System CompactFlash directory:
File Length Name/status
1 1614 Debug.....(User info is append to flash)
2 204 Debug_clock......(Clock time when debug entered is also append to flash)
R1#more flash:Debug
Line User Host(s) Idle Location
0 con 0 idle 00:00:00
* 66 vty 0 idle 00:00:00 XYZ
R2#more flash:Debug_Clock
12:43:15.263 UTC Sun Nov 18 2012
R2#
C) Interface Events:
In this example applet is configure to measure rxload on the interface.
Two applets are configure:
1) When Rx load is above 50% then router will apply access-list on the interface fa0/1 to allow only important traffic and block the unwanted traffic.
2) When Rx load goes below 25, the router will remove applied access-list from the interface fa0/1 to allow all traffic.
Configuration:
event manager applet Interface_Load_UP
event tag 1 interface name FastEthernet1/0 parameter rxload entry-op gt entry-val 127 entry-type value poll-interval 30
action 1.1 cli command "conf t"
action 1.2 cli command "int fa1/0"
action 1.3 cli command "ip access-group IMP_TRAFFIC in "
action 1.4 cli command "end"
event manager applet Interface_Load_Down
event tag 1 interface name FastEthernet1/0 parameter rxload entry-op lt entry-val 25 entry-type value poll-interval 30
action 1.3 cli command "no ip access-group IMP_TRAFFIC in "
Verification:
R1#sh int fa1/0 | in load
reliability 255/255, txload 1/255, rxload 1/255..(Rxload is 1)
reliability 255/255, txload 139/255, rxload 139/255....(Rxload is increase more 50% i.e.139)
R1#(As soon Rxload increase by 50%, causing to triggered 1 st event)
*Nov 18 02:19:55.403: %HA_EM-6-LOG: Interface_Load : DEBUG(cli_lib) : : CTL : cli_open called.
*Nov 18 02:19:55.423: %HA_EM-6-LOG: Interface_Load : DEBUG(cli_lib) : : OUT : R1>
*Nov 18 02:19:55.427: %HA_EM-6-LOG: Interface_Load : DEBUG(cli_lib) : : IN : R1>enable
: R1#conf t
: R1(config)#int fa1/0
: R1(config-if)#ip access-group IMP_TRAFFIC in....(Access-list apply to interface)
*Nov
R1#18 02:19:55.827: %HA_EM-6-LOG: Interface_Load : DEBUG(cli_lib) : : OUT : R1(config-if)#
*Nov 18 02:19:55.831: %HA_EM-6-LOG: Interface_Load : DEBUG(cli_lib) : : IN : R1(config-if)#end
*Nov 18 02:19:55.839: %SYS-5-CONFIG_I: Configured from console by on vty0 (EEM:Interface_Load)
*Nov 18 02:19:55.851: %HA_EM-6-LOG: Interface_Load : DEBUG(cli_lib) : : OUT : R1#
*Nov 18 02:19:55.855: %HA_EM-6-LOG: Interface_Load : DEBUG(cli_lib) : : CTL : cli_close called.
R1#sh ip access-lists
Extended IP access list IMP_TRAFFIC
10 permit tcp any any eq www
20 permit tcp any any eq telnet
30 deny icmp any any (10 matches)............(Router Start dropping ICMP packets)
R1#sh run int fa1/0
Building configuration...
Current configuration : 159 bytes
interface FastEthernet1/0
bandwidth 64
ip address 10.1.1.1 255.255.255.0
load-interval 30
duplex full
speed 100
end
reliability 255/255, txload 19/255, rxload 19/255(As soon as Rxload goes below 25, R1 trigger 2nd event)
R1#
*Nov 18 02:21:31.367: %HA_EM-6-LOG: Interface_Load_Down : DEBUG(cli_lib) : : CTL : cli_open called.
*Nov 18 02:21:31.375: %HA_EM-6-LOG: Interface_Load_Down : DEBUG(cli_lib) : : OUT : R1>
*Nov 18 02:21:31.379: %HA_EM-6-LOG: Interface_Load_Down : DEBUG(cli_lib) : : IN : R1>enable
*Nov 18 02:21:31.395: %HA_EM-6-LOG: Interface_Load_Down : DEBUG(cli_lib) : : OUT : R1#
*Nov 18 02:21:31.399: %HA_EM-6-LOG: Interface_Load_Down : DEBUG(cli_lib) : : IN : R1#conf t
*Nov 18 02:21:31.423: %HA_EM-6-LOG: Interface_Load_Down : DEBUG(cli_lib) : : OUT : Enter configuration commands, one per line. End with CNTL/Z.
R1#
*Nov 18 02:21:31.423: %HA_EM-6-LOG: Interface_Load_Down : DEBUG(cli_lib) : : OUT : R1(config)#
*Nov 18 02:21:31.427: %HA_EM-6-LOG: Interface_Load_Down : DEBUG(cli_lib) : : IN : R1(config)#int fa1/0
*Nov 18 02:21:31.455: %HA_EM-6-LOG: Interface_Load_Down : DEBUG(cli_lib) : : OUT : R1(config-if)#
*Nov 18 02:21:31.459: %HA_EM-6-LOG: Interface_Load_Down : DEBUG(cli_lib) : : IN : R1(config-if)#no ip access-group IMP_TRAFFIC in....(Removing Access-list)
*Nov 18 02:21:31.579: %HA_EM-6-LOG: Interface_Load_Down : DEBUG(cli_lib) : : OUT : R1(config-if)#
*Nov 18 02:21:31.579: %HA_EM-6-LOG: Interface_Load_Down : DEBUG(cli_lib) : : IN : R1(config-if)#end
*Nov 18 02:21:31.587: %SYS-5-CONFIG_I: Configured from console by on vty0 (EEM:Interface_Load_Down)
*Nov 18 02:21:31.599: %HA_EM-6-LOG: Interface_Load_Down : DEBUG(cli_lib) : : OUT : R1#
*Nov 18 02:21:31.603: %HA_EM-6-LOG: Interface_Load_Down : DEBUG(cli_lib) : : CTL : cli_close called.
D) SNMP event Detector:
In this example EEM applet reads the SNMP variable and it will be triggered when the CPU goes above 60 %.you can customized applet according to the need. However, caution should be exercised to consider the file system free space before deploying the applet.
For SNMP OID you can use SNMP Object Navigator
Configuration:
event manager applet HIGH-CPU
event snmp oid 1.3.6.1.4.1.9.9.109.1.1.1.1.3 get-type next entry-op gt entry-val 60 poll-interval 5
action 0.1 cli command "enable"
action 0.2 syslog msg "Capturing high cpu information to flash:"
action 0.3 cli command "term length 0"
action 1.1 cli command "show process cpu sorted | append flash:EEM_CPU"
action 1.4 cli command "show ip traffic | append flash:EEM_TRAFFIC"
action 1.4 cli command "show logging | append flash:EEM_LOGS"
action 4.2 syslog msg "Removing EEM APPLET from running_config"
action 9.2 cli command "configure terminal"
action 9.3 cli command "no event manager applet HIGH-CPU"
action 9.4 cli command "end"
action 9.5 cli command "term default length"
Verification:
R2#
*Nov 18 12:30:53.139: %HA_EM-6-LOG: HIGH-CPU: Capturing high cpu information to flash:
*Nov 18 12:30:53.371: %HA_EM-6-LOG: HIGH-CPU: Removing EEM APPLET from running_config
R2#sh flash:
1 22477 EEM_CPU
2 2665 EEM_LOGS
E) TCL (Tool Control Language) is a scripting language used extensively by Cisco to facilitate the testing and automating of various functions in the IOS.
In this example, small TCL script configured to check reachability of Branch devices from the Core router.
R1#tclsh
R1(tcl)#
R1(tcl)#foreach VAR {
+>(tcl)#192.168.1.1
+>(tcl)#192.168.2.1
+>(tcl)#192.168.3.1
+>(tcl)#192.168.4.1
+>(tcl)#} { puts [exec "ping $VAR"] }
Sending 5, 100-byte ICMP Echos to 192.168.1.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 20/58/120 ms
Sending 5, 100-byte ICMP Echos to 192.168.2.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/40/104 ms
Sending 5, 100-byte ICMP Echos to 192.168.3.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 16/72/128 ms
Sending 5, 100-byte ICMP Echos to 192.168.4.1, timeout is 2 seconds:
U.U.U
Success rate is 0 percent (0/5)
R1(tcl)#
Related Information
Writing Embedded Event Manager Policies Using the Cisco IOS CLI
Cisco EEM Best Practices
Embedded Event Manager Overview
emm through event manager scheduler script
Writing Embedded Event Manager Policies Using Tcl
EEM Script For Periodically Clearing Interface Counters Using Regular Expression
Base Initial configuration:
- Mark as Read
- Mark as New
- Bookmark
- Permalink
Thanks for giving wonderful information..
I will try this and share my experience.
- Mark as Read
- Mark as New
- Bookmark
- Permalink
Hello Archit,
Thanks for valuable feedback
Reagards,
Ashish
(Technical community manager-NI)
- Mark as Read
- Mark as New
- Bookmark
- Permalink
Hi Ashish,
It's a nice Document. Very informative.
I had an requirement for which i was searching for EEM script and found your DOC. It was very informative.
In my scenario if any user logged into switch is removing TACACS configuration is it possible to send auto alert to LMS is it achievable through EEM script. Please can you help in this.
Ajith
- Mark as Read
- Mark as New
- Bookmark
- Permalink
Dear Ajith,
Thanks for your positive feedback and private mail; really appreciated .you can check answer for your query in discussion thread you have opened.
Thanks and Regards,
Ashish Shirkar
(Technical Community Manager-NI)
- Mark as Read
- Mark as New
- Bookmark
- Permalink
Dear Ashish,
Thank You for sharing this useful information.
I have written an EEM script that is using IP SLA but I have some doubts about it, weather it will work in Production
the way I preceives it.
Before I share my configuration let me breifly describe what I am trying to accomplish.
I have 2 ASA 5585 at the Primary Site which is the Data Center and both firewalls are connected to 2 6506E which are operating in VSS Mode.VSS at the Data Center site is connected upstream to the Aggregation Router that is connected with Multiple Branch Routers via GRE Tunnels.The routes are being exchanged between Aggregation Router and VSS via ospf.At VSS we have Static Routes point to primary firewall that is in Active Mode (2nd Firewall is in Standby Mode).
Now the Same Exact Topology exists the Disaster Recovery Site. 2 6506 E are operating in VSS Mode. VSS ports at DR Site used to connect with Primary Firewall are in Shutdown Mode but on the end of the link at Firewall the ports are in no shut mode.Customer is using same exact private RFC 1918 address at both sites Data Center and Disaster Recovery Site. Both sites are connected to Each Other Via Nexus 5K Extended Reach Fiber Link.Also VSS at the Data Center site and Disaster Recovery Site are also connected with extended reach link that running ospf on it.
Now in the even if both Firewalls Primary and Seondary goes down at Data Center Site I want VSS Ports at the Disaster Recover site that is connected to Firewall at Disaster Recover Site should go to no shutdown mode and when any of the Firewall at Data Center Site becomes available again I want VSS ports at the Disaster Recovery site should go back to shutdown mode.To acheive this I have written the EEM in conjuction with IP SLA.
Could You Please spare some time can validate if this is going to work.
Your assistance in this will be highly appreciated.
Configuration of the Failover In The Event Of Wan Link Failure at DC Site
Configuration at the DR VSS Switch
IP SLA To Monitor The Data Center Primary Firewall CORE-DC-FW01 Outside Interface
Ip sla 1
Icmp-echo x.x.x.x (Pinging outside interface ip address of the Primary Firewall CORE-DC-FW01)
timeout 500
frequency 3
ip sla schedule 1 life forever start-time now
track 1 ip sla 1 reachability
delay down 8 up 10
EEM Script
event manager applet FAILOVERTODR
event track 1 state down
action 1.1 cli command “config t”
action 1.2 cli command “interface tengigabitethernet 1/2/5 ” (We are brining up the DR VSS 1st Interface that is connected with CORE-DR-FW01)
action 1.3 cli command “no shutdown”
action 1.4 cli command “exit”
action 1.5 cli command “interface tengigabitethernet 2/2/5 ” (We are brining up the DR VSS 2nd Interface that is connected with DR CORE-DR-FW01)
action 1.6 cli command “no shutdown”
action 1.7 syslog msg “Interface tengigabitethernet 1/2/5 and tengigabitethernet 2/2/5 were brought up via EEM”
event manager applet FAILOVERTODC
event track 1 state up
action 1.2 cli command “interface tengigabitethernet 1/2/5 ” (We are shutting down the DR VSS 1st Interface that is connected with DR CORE-DR-FW01)
action 1.3 cli command “shutdown”
action 1.5 cli command “interface tengigabitethernet 2/2/5 ” (We are Shutting Down the DR VSS 2nd Interface that is connected with DR CORE-DR-FW01)
action 1.6 cli command “shutdown”
action 1.7 syslog msg “Interface tengigabitethernet 1/2/5 and tengigabitethernet 2/2/5 were Shutdown via EEM”
Furhter will the 2nd EMM script will iterate and can create Loops or will it have any negative impact on the device it is configured on.
Looking forward for your reply.
Usman.
- Mark as Read
- Mark as New
- Bookmark
- Permalink
Ohh Wow..
Very Nice Explanation
Thanks Ashish for sharing the same
- Mark as Read
- Mark as New
- Bookmark
- Permalink
Hello ashirk
your script "high-cpu" gives me no result, when I put "sh flash" it shows me " "Open device slot0 failed (Bad device info block)"
And I want to create a script to display a traffic interface but I not know how . you can help me?
- Mark as Read
- Mark as New
- Bookmark
- Permalink
Hello Ashirkar,
I did what you wrote but it didn't work. I guess it doesn`t work because my router 2911 ask a user and password y it goes directly to privileged mode
"username rsnpower2 privilege 15 secret 4 LgaZhZWEWKivYt.uo6bM87s3eMiIPtS50PDGv2K1IUA"
So, if the firts cli command is "enable", but my router has a password, then how it would do to get in privileged mode (#) and it can use the next cli command.
When i use: "Show event manager history events" it shows that my applet is active and had a track event.
I would be veru grateful for your answer.
Best regards,
Sandro
- Mark as Read
- Mark as New
- Bookmark
- Permalink
Does anyone know how to get EEM scripts to direct "show" command output or "more" command output to the console terminal? It seems EEM suppresses "show run" commands.
Jim
- Mark as Read
- Mark as New
- Bookmark
- Permalink
I have a Nexus switch whose OS does not support IP SLA.
I need to have a script or a tool to ping to a next hop and send alert mails on even a single drop.
Can I acheive this using only EEM tools? If yes, can you share how to?
Thanks in advance!!
Naveen
- Mark as Read
- Mark as New
- Bookmark
- Permalink
Great post
I have a doubt
What if i want to save the running-config to tftp?
for testing purposes i tried this to save the running-config every 5 minutes but didn't work
event manager applet RESPALDOTEST
event timer cron name RESPALDOTEST cron-entry "5 * * * *"
action 1 cli command "enable"
action 2 cli command "copy running-config tftp:"
action 3 cli command "172.16.20.123"
action 4 cli command "respaldotest"
action 5 cli command "end"
can you help me?
- Mark as Read
- Mark as New
- Bookmark
- Permalink
Hi ysantizo1,
you could do it like this:
action 2 cli command "copy running-config tftp://172.16.20.123/respaldotest"
action 4 cli command "y"
But I prefer the "archive" command:
http://www.cisco.com/c/en/us/td/docs/ios/fundamentals/command/reference/cf_book/cf_a1.html#wp1018716
and you can soemthing like this:
archive
log config
path tftp://172.16.20.123/
write-memory
This will you copy your running-config everytime if you execute "wr" or "copy run start" to your tftp-server.
kind regards,
Flo
- Mark as Read
- Mark as New
- Bookmark
- Permalink
Thanks for your response Florian
I've tried this
but didn't work
i guess that is for the next lines that are interactive and ask you for the host again
i didn't use the archive command because i want it to be fully automated
any advise?
- Mark as Read
- Mark as New
- Bookmark
- Permalink
I tried too with some empty cli commands like this
action 3 cli command ""
action 4 cli command ""
and still nothing
- Mark as Read
- Mark as New
- Bookmark
- Permalink
try soemting like this:
event manager applet SAVING-RUNNING-TO-TFTP
description Backup running-config to TFTP 172.16.20.123
event syslog pattern "%SYS-5-CONFIG_I: Configured from"
action 0.1 info type routername
action 1.1 cli command "copy run tftp" pattern "Address"
action 1.2 cli command "172.16.20.123" pattern "filename"
action 1.3 cli command "$_info_routername-confg"
action 2.0 syslog priority informational msg "Configuration change detected. Write to TFTP succesfully executed"!
Every time if logout from the configuration mode you get the syslog-message %SYS-5-CONFIG and with this applet you grep this pattern and then saving your running-config to your tftp-server
greetz
flo
