Core Issue
This issue can be hardware or software related.
Resolution
This type of crash does not clearly indicate a hardware or a software failure. Occasionally, this problem may occur once and not recur.
If you have the output of a show stacks or show tech-support command from your Cisco device, you can use the Output Interpreter. You must be a registered customer. Also, you must be logged in and have JavaScript enabled.
