ashirkar
Level 7
Level 7
Introduction:
OSPF is link state routing protocol that works on the concept of areas. All areas must have same LSDB (link state database); hence OSPF summarization can only done on the border routers i.e. on ABR (Area border router) and ASBR (Autonomous system boundary router).In this document we discussed about route summarization between the areas.
Background:
Summarization between areas can be done on ABR by using single command under OSPF process:
area [area-id] range [ ip-address ] [mask ] [advertise | not-advertise |cost {cost}]
A) area-id= Identifier of the area about which routes are to be summarized
B) [ ip-address ] [mask]= Summary route to be advertise in areas
Summary route calculation:
Only 3 steps are required to calculate summary route
     1) Convert the addresses to binary format
     2) Locate the bit where the common pattern of digits ends
     3) The number of common bits is subnet mask and the summary route number is represented by the first IP address in the block.
Let’s assume the following networks in routing table:
192.168.0.0/24
192.168.1.0/24
192.168.2.0/24
Prefix’s
Binary Splitting
  8        16       24         32
192.168.0.0
11000000 10101000 0000 0000 000000000
192.168.1.0
11000000 10101000 0000 0001 000000000
192.168.2.0
11000000 10101000 0000 0010 000000000
From the above table it shows first 22 bits are common, so summary route subnet mask is /22 i.e. 255.255.252.0 and summarized route is 192.168.0.0/22
C) advertise = By default type 3 LSA is advertise
D) not-advertise =Its optional and used to filter type 3 LSA component of the networks specify in range command.
E) Cost =It’s optional When we have multiple ABRs we can Advertise summary route with cost for route manipulation.
Configuration overview:
In following example router ABR1 is directly connected to R1 in area 1 and to R2 in backbone area0.
Topology Diagram:
On R1 loopbacks are created loopbacks for generating network prefixes and advertise them into OSPF as follow:
R1#sh ip interface brief | include Lo
Loopback0                  192.168.0.1     YES manual up                    up
Loopback1                  192.168.1.1     YES manual up                    up
Loopback2                  192.168.2.1     YES manual up                    up
R2 in area 0 learns Type3 LSA for loopbacks created on R1 via ABR1 and installed into routing table as shown in below output:
R2#sh ip ospf database | Beg Summary
                Summary Net Link States (Area 0)
Link ID         ADV Router      Age         Seq#       Checksum
10.1.1.0        10.1.1.6        260         0x80000001 0x00B463
192.168.0.0     10.1.1.6        102         0x80000001 0x00B8FD
192.168.1.0     10.1.1.6        102         0x80000001 0x00AD08
192.168.2.0     10.1.1.6        102         0x80000001 0x00A212
R2#sh ip ospf database summary 192.168.0.0
            OSPF Router with ID (10.1.1.5) (Process ID 100)
  Routing Bit Set on this LSA
  LS age: 7
  Options: (No TOS-capability, DC, Upward)
  LS Type: Summary Links(Network)
  Link State ID: 192.168.0.0 (summary Network Number)
  Advertising Router: 10.1.1.6
  LS Seq Number: 80000002
  Checksum: 0x5C62
  Length: 28
  Network Mask: /24
        TOS: 0  Metric: 2
R2#sh ip route | Begin Gateway
Gateway of last resort is not set
     10.0.0.0/30 is subnetted, 2 subnets
O IA    10.1.1.0 [110/2] via 10.1.1.6, 00:00:36, FastEthernet0/0
C       10.1.1.4 is directly connected, FastEthernet0/0
O IA 192.168.0.0/24 [110/3] via 10.1.1.6, 00:00:36, FastEthernet0/0
O IA 192.168.1.0/24 [110/3] via 10.1.1.6, 00:00:36, FastEthernet0/0
O IA 192.168.2.0/24 [110/3] via 10.1.1.6, 00:00:36, FastEthernet0/0
Configuring ABR1 to summarized loopback subnets available on R1 i.e.
192.168.0.0/24
192.168.1.0/24
192.168.2.0/24
ABR1(config)#router ospf 100
ABR1(config-router)#area 1 range 192.168.0.0 255.255.252.0
ABR1(config-router)#end
After configuring summarization on ABR1, R2 receives Type 3 i.e.192.168.0.0/22 not individual type 3 LSA for each loopback address from ABR1 shown below:
O IA    10.1.1.0 [110/2] via 10.1.1.6, 00:16:36, FastEthernet0/0
O IA 192.168.0.0/22 [110/3] via 10.1.1.6, 00:06:00, FastEthernet0/0
Discard route:
It's interesting to look at these summary routes on the ABR, which is responsible for doing all of the summarization. The ABR also includes the summary routes, but they aren't real routes, so it simply points them to its Null0 interface called discard routes. They help to prevent routing loops during summarization:
ABR1#sh ip route ospf
O    192.168.0.0/24 [110/2] via 10.1.1.1, 00:15:01, FastEthernet0/0
O    192.168.1.0/24 [110/2] via 10.1.1.1, 00:15:01, FastEthernet0/0
O    192.168.2.0/24 [110/2] via 10.1.1.1, 00:15:01, FastEthernet0/0
O    192.168.0.0/22 is a summary, 00:15:01, Null0
Discard route is generated by default, and you don't need to create it. If you want to disable creation of the discard route, you can use the no discard-route command as follows:
ABR1(config-router)#discard-route internal
Benefits of OSPF Summarization:
1) Reduce the number of routing table entries.
2) Reduce Type3 flooding and saves router CPU resource.
3) Summarization can also be used for route manipulation by using longest match prefix concept
Related Information:
OSPF Design Guide
OSPF  Vesion 2
gornication
Hello!
What routing loops are we talking about? Is this the case when the destination address is not included in the /24 but is part of the /22 with the presence of the default route?
