05-22-2011 12:51 AM - edited 03-01-2019 04:40 PM
OTV adjacency is formed across the layer 3 multicast clouds by exchanging L1 ISIS Hello packets.
After the OTV configuration completed, enabling the join interface sends any source IGMP v3 join on that interface.
interface Ethernet1/31
description [OTV-JOIN-INTERFACE]
vrf member OTV
ip address 10.10.15.6/30
ip router eigrp 10
ip igmp version 3
SITE1-OED1(config-if)# int eth 1/31
SITE1-OED1(config-if)# no shut
SITE1-AGG1%OTV# show ip mroute
IP Multicast Routing Table for VRF "OTV"
(*, 239.1.1.1/32), uptime: 0.283775, igmp pim
Incoming interface: Ethernet1/5, RPF nbr: 10.10.15.1 <<Interface facing Multicast RP
Outgoing interface list: (count: 1)
Ethernet1/9, uptime: 0.283711, igmp <<< Interface connecting to OTV VDC SITE1-OED1
When you enable the OTV overlay interface, the switch will generate a L1 ISIS hello packet with the source IP address as the OTV join interface and the destination IP address as the OTV control-group.
(*, 239.1.1.1/32), uptime: 00:16:00, igmp pim ip
Ethernet1/9, uptime: 00:16:00, igmp
(10.10.15.6/32, 239.1.1.1/32), uptime: 00:00:19, ip mrib pim
<<< S,G entry represents Multicast packet received from 10.10.15.6
Incoming interface: Ethernet1/9, RPF nbr: 10.10.15.6
Ethernet1/9, uptime: 00:00:19, mrib, (RPF)
After all the four OTV edge devices are configured and enabled, the multicast transport network should show all the sources
(*, 239.1.1.1/32), uptime: 00:23:13, igmp pim ip
Ethernet1/9, uptime: 00:23:13, igmp
(10.10.15.6/32, 239.1.1.1/32), uptime: 00:07:33, ip mrib pim <<< SITE1-OED1
Outgoing interface list: (count: 2)
Ethernet1/5, uptime: 00:05:44, pim
Ethernet1/9, uptime: 00:07:33, mrib, (RPF)
(10.10.16.6/32, 239.1.1.1/32), uptime: 00:04:48, ip mrib pim <<< SITE1-OED2
Ethernet1/9, uptime: 00:04:48, mrib
(10.10.17.6/32, 239.1.1.1/32), uptime: 00:04:21, ip mrib pim <<< SITE2-OED1
Ethernet1/9, uptime: 00:04:21, mrib
(10.10.18.6/32, 239.1.1.1/32), uptime: 00:03:46, ip mrib pim <<< SITE2-OED2
Ethernet1/9, uptime: 00:03:46, mrib
You can also monitor the OTV control packets statistics as below.
SITE1-AGG1%OTV# show ip mroute summary
Total number of routes: 6
Total number of (*,G) routes: 1
Total number of (S,G) routes: 4
Total number of (*,G-prefix) routes: 1
Group count: 1, rough average sources per group: 4.0
Group: 239.1.1.1/32, Source count: 4
Source packets bytes aps pps bit-rate oifs
(*,G) 7 10106 1443 0 0.000 bps 1
10.10.15.6 73 86674 1187 0 1349.600 bps 2
10.10.16.6 96 76987 801 0 1429.600 bps 1
10.10.17.6 103 81610 792 0 1416.267 bps 1
10.10.18.6 155 144435 931 0 4092.800 bps 1
You can verify the Adjacency using the below command:
SITE1-OED1# show otv adjacency detail
Overlay Adjacency database
Overlay-Interface Overlay1 :
Hostname System-ID Dest Addr Up Time State
SITE1-OED2 0024.986f.bac4 10.10.16.6 00:05:31 UP
HW-St: Up Peer-ID: 3
SITE2-OED1 0026.51ce.0f43 10.10.17.6 00:46:29 UP
HW-St: Up Peer-ID: 2
SITE2-OED2 0026.51ce.0f44 10.10.18.6 00:46:29 UP
HW-St: Up Peer-ID: 1
If there is any issue in establishing OTV ISIS adjacency, you can look at the ISIS adjacency log as below:
SITE1-OED1# show otv isis internal event-history adjacency
ISIS default process
adjacency Events for ISIS process
2011 May 21 08:54:53.773678 isis_otv default [10371]: (Overlay1) : LAN adj L1
SITE2-OED1 over Overlay1 - UP
2011 May 21 08:54:53.773662 isis_otv default [10371]: [10376]: Sent OTV add adja
cency for overlay:Overlay1, addr: 10.10.17.6
2011 May 21 08:54:53.653906 isis_otv default [10371]: (Overlay1) : Set adjacency
SITE2-OED1 over Overlay1 IPv4 address to 10.10.17.6
2011 May 21 08:54:53.653827 isis_otv default [10371]: (Overlay1) : LAN adj L1
SITE2-OED1 over Overlay1 - INIT (New)
2011 May 21 08:54:53.653799 isis_otv default [10371]: [10376]: Initialize adj fo
r L1 MT-0 for iib Overlay1
You can clear the log as below:
SITE1-OED1# clear otv isis event-history
Verify Overlay interface is up.
OTV Overlay Information
Overlay interface Overlay1
VPN name : Overlay1
VPN state : UP
Extended vlans : 100-200 (Total:101)
Control group : 239.1.1.1
Data group range(s) : 232.1.1.0/26
Join interface(s) : Eth1/31 (10.10.15.6)
Site vlan : 95 (up) <<< Site VLAN should be Up
Site VLAN should be in spanning tree forwarding on at least one port in the OTV VDC. If not, the data will not be forwarded across the OTV even though the OTV overlay is up and adjacency is forwarded with other peers.
After the OTV adjacency is setup, OTV process creates implicit tunnels for each discovered peer. These tunnels will be used to forward the data across OTV to the respective site.
show otv internal event-history debug
2011 May 21 10:10:58.428388 otv [10358]: [10361]: otv_tunnel_gre_add Tunnel (10.
10.15.6, 10.10.17.6) does not exist, creating NEW
2011 May 21 10:10:58.426206 otv [10358]: [10361]: Received ISIS add adjacency me
ssage for (Overlay1, 10.10.17.6) , sid 0026.51ce.0f43
Tunnel process in the NX-OS creates these tunnels based on the request from OTV process. You can verify the implicit tunnels as below:
SITE1-OED1# show tunnel internal implicit otv brief
Interface Status IP Address Encap type MTU
Tunnel16424 up -- GRE/IP 9178
Tunnel16425 up -- GRE/IP 9178
SITE1-OED1# show tunnel internal implicit otv detail
Tunnel16424 is up
MTU 9178 bytes, BW 9 Kbit
Transport protocol is in VRF "OTV"
Tunnel protocol/transport GRE/IP
Tunnel source 10.10.15.6, destination 10.10.18.6
Tx
0 packets output, 1 minute output rate 0 packets/sec
Rx
0 packets input, 1 minute input rate 0 packets/sec
Tunnel16425 is up
Tunnel source 10.10.15.6, destination 10.10.17.6
Tx
Rx
The below command will shows the mapping between OTV adjacency and implicit tunnel.
SITE1-OED1# show otv internal adjacency
System-ID Dest Addr Adj-State TM_State Up Time Adj-State inAS
0024.986f.bac4 10.10.16.6 default default 00:05:59 UP UP
HW-St: Up Curr-Peer-St: Up, New-Peer_St: Default Peer-ID: 3 N Tunnel16426
0026.51ce.0f43 10.10.17.6 default default 00:46:57 UP UP
HW-St: Up Curr-Peer-St: Up, New-Peer_St: Default Peer-ID: 2 N Tunnel16425
0026.51ce.0f44 10.10.18.6 default default 00:46:58 UP UP
HW-St: Up Curr-Peer-St: Up, New-Peer_St: Default Peer-ID: 1 N Tunnel16424
SITE1-OED1#
very thanks for the tips!
Thanks for the info however this does not help me to troubleshoot an issue i am seeing. :-)
For instance i have 4 nexus 7000 each having an agg VDC and a OTV VDC when all is good each OTV VDC sees 3 adjacencies. However after trying a failover (shutting down a nexus 7000) when that 7000 comes back up 1 out of 3 tries it only gets 2 adjacencies this happens random across all 4 7000s when I shut one down. It's only after i shut/ no shut the overlay interface do i get all 3 adjacencies. The multicast RPs are 2 of the nexus 7000s using msdp. It is extremely frustrating because if the wrong adjacency doesn't come up its a black hole for traffic 100% failure of OTV traffic for the vlans handled by that AED. I plan on calling a tac case in tomorrow I will let you know of the outcome.
Hi Daniel,
i had the same issue during the implemantation of OTV inside the DC. Do you have contacted the TAC ? Have you got some news about? Is it a BUG ?
Hi Daniel,
Has this issue been resolved? If so, what was the solution?
