01-05-2012 05:41 AM 03-01-2019 04:45 PM 更新
Loop prevention in BGP is done by verifying the AS number in the AS Path. If the receiving router sees its own AS number in the AS Path of the received BGP packet, the packet is dropped. The receiving Router assumes that the packet was originated from its own AS and has reached the same place from where it originated initially.
The feature could be a disaster if customers are using same AS number along the various sites and disallows customer sites having identical AS numbers to be linked by another AS number. In such a scenario, routing updates from one site will be dropped when the other site receives them.
To override this feature, AS-Override function causes to replace the AS number of originating router with the AS number of the sending BGP router. The command is neighbor ip-address as-override and can only be executed under the VPNv4 address-family.
Here are the steps to illustrate the As-Override process
In this Topology, router PE-1 and PE-2 forms the Service Provider MPLS Cloud. The two routers are connected via fast Ethernet interface 0/0 and are running OSPF (Area 0) routing protocol. MPLS is configured on physical links (Fast Ethernet 0/0) of the SP network. Tagging is done via LDP and the labels are assigned in the range 100-199 on PE1 and 200-299 on PE2.
TAURUS and CINDY are the two customers with multiple sites (Site-A and Site-B). Customer TAURUS is operating under AS 100 and customer CINDY is operating under AS 200.
VPNv4 neighbor relationship is configured between (vrf TAURUS and vrf CINDY)
Routes from each site are advertised to PE routers within EBGP session. These routes are further propagated to next PE routers which are then forwarded to respective Customer-Site.
Note: All configurations are tested on Cisco 3700 series router with IOS 12.4.
PE-1PE-2
hostname PE-1 ip cef ip vrf CINDY rd 1:200 route-target export 1:200 route-target import 1:200 ip vrf TAURUS rd 1:100 route-target export 1:100 route-target import 1:100 no ip domain lookup mpls label range 100 199 mpls label protocol ldp interface Loopback0 ip address 1.1.1.1 255.255.255.255 interface FastEthernet0/0 ip address 10.12.12.1 255.255.255.0 duplex auto speed auto mpls ip interface Serial0/0 ip vrf forwarding TAURUS ip address 192.13.13.1 255.255.255.252 clock rate 2000000 interface Serial0/1 ip vrf forwarding CINDY ip address 192.14.14.1 255.255.255.252 clock rate 2000000 router ospf 10 router-id 1.1.1.1 log-adjacency-changes network 1.1.1.1 0.0.0.0 area 0 network 10.12.12.1 0.0.0.0 area 0 router bgp 121 no synchronization bgp log-neighbor-changes network 11.11.11.11 mask 255.255.255.255 neighbor 2.2.2.2 remote-as 121 neighbor 2.2.2.2 update-source Loopback0 neighbor 2.2.2.2 next-hop-self no auto-summary address-family vpnv4 neighbor 2.2.2.2 activate neighbor 2.2.2.2 send-community both exit-address-family address-family ipv4 vrf TAURUS redistribute connected neighbor 192.13.13.2 remote-as 100 neighbor 192.13.13.2 activate neighbor 192.13.13.2 as-override no synchronization exit-address-family address-family ipv4 vrf CINDY redistribute connected neighbor 192.14.14.2 remote-as 200 neighbor 192.14.14.2 activate neighbor 192.14.14.2 as-override no synchronization exit-address-family mpls ldp router-id Loopback0 exit | hostname PE-2 ip cef ip vrf CINDY rd 1:200 route-target export 1:200 route-target import 1:200 ip vrf TAURUS rd 1:100 route-target export 1:100 route-target import 1:100 no ip domain lookup mpls label range 200 299 mpls label protocol ldp interface Loopback0 ip address 2.2.2.2 255.255.255.255 interface Loopback1 ip address 22.22.22.22 255.255.255.255 interface FastEthernet0/0 ip address 10.12.12.2 255.255.255.0 duplex auto speed auto mpls ip interface Serial0/0 ip vrf forwarding TAURUS ip address 192.23.23.1 255.255.255.252 clock rate 2000000 interface Serial0/1 ip vrf forwarding CINDY ip address 192.26.26.1 255.255.255.252 clock rate 2000000 router ospf 10 router-id 2.2.2.2 log-adjacency-changes network 2.2.2.2 0.0.0.0 area 0 network 10.12.12.2 0.0.0.0 area 0 router bgp 121 no synchronization bgp log-neighbor-changes network 22.22.22.22 mask 255.255.255.255 neighbor 1.1.1.1 remote-as 121 neighbor 1.1.1.1 update-source Loopback0 neighbor 1.1.1.1 next-hop-self no auto-summary address-family vpnv4 neighbor 1.1.1.1 activate neighbor 1.1.1.1 send-community both exit-address-family address-family ipv4 vrf TAURUS redistribute connected neighbor 192.23.23.2 remote-as 100 neighbor 192.23.23.2 activate neighbor 192.23.23.2 as-override no synchronization exit-address-family address-family ipv4 vrf CINDY redistribute connected neighbor 192.26.26.2 remote-as 200 neighbor 192.26.26.2 activate neighbor 192.26.26.2 as-override no synchronization exit-address-family mpls ldp router-id Loopback0 exit |
TAURUS_Site-ACINDY_Site-ATAURUS_Site-BCINDY_Site-B
hostname TAURUS-Site_A ip cef no ip domain lookup interface Loopback0 ip address 10.3.3.3 255.255.255.255 interface Serial0/0 ip address 192.13.13.2 255.255.255.252 clock rate 2000000 router bgp 100 no synchronization bgp log-neighbor-changes network 10.3.3.3 mask 255.255.255.255 neighbor 192.13.13.1 remote-as 121 no auto-summary exit | hostname CINDY-SITE_A ip cef no ip domain lookup interface Loopback0 ip address 10.4.4.4 255.255.255.255 interface Serial0/0 ip address 192.14.14.2 255.255.255.252 clock rate 2000000 router bgp 200 no synchronization bgp log-neighbor-changes network 10.4.4.4 mask 255.255.255.255 neighbor 192.14.14.1 remote-as 121 no auto-summary exit | hostname TAURUS-Site_B ip cef no ip domain lookup interface Loopback0 ip address 10.5.5.5 255.255.255.255 interface Serial0/0 ip address 192.23.23.2 255.255.255.252 clock rate 2000000 router bgp 100 no synchronization bgp log-neighbor-changes network 10.5.5.5 mask 255.255.255.255 neighbor 192.23.23.1 remote-as 121 no auto-summary exit | hostname CINDY-SITE_B ip cef no ip domain lookup interface Loopback0 ip address 10.6.6.6 255.255.255.255 interface Serial0/0 ip address 192.26.26.2 255.255.255.252 clock rate 2000000 router bgp 200 no synchronization bgp log-neighbor-changes network 10.6.6.6 mask 255.255.255.255 neighbor 192.26.26.1 remote-as 121 no auto-summary exit |
PE-1#show ip bgp vpnv4 all summary
< output truncated >
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
2.2.2.2 4 121 115 116 15 0 0 01:09:16 4
192.13.13.2 4 100 70 74 15 0 0 00:46:42 1
192.14.14.2 4 200 41 44 15 0 0 00:36:14 1
PE-2#show ip bgp vpnv4 all summary
1.1.1.1 4 121 119 118 15 0 0 01:11:22 4
192.23.23.2 4 100 53 56 15 0 0 00:48:07 1
192.26.26.2 4 200 41 44 15 0 0 00:36:46 1
PE-1#sh ip route vrf TAURUS bgp
192.23.23.0/30 is subnetted, 1 subnets
B 192.23.23.0 [200/0] via 2.2.2.2, 00:25:32
10.0.0.0/32 is subnetted, 2 subnets
B 10.3.3.3 [20/0] via 192.13.13.2, 00:35:30
B 10.5.5.5 [200/0] via 2.2.2.2, 00:33:03
PE-1#show ip route vrf CINDY bgp
192.26.26.0/30 is subnetted, 1 subnets
B 192.26.26.0 [200/0] via 2.2.2.2, 00:27:05
B 10.6.6.6 [200/0] via 2.2.2.2, 00:32:36
B 10.4.4.4 [20/0] via 192.14.14.2, 00:34:51
BGP table version is 15, local router ID is 11.11.11.11
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
Route Distinguisher: 1:100 (default for vrf TAURUS)
*> 10.3.3.3/32 192.13.13.2 0 0 100 i
*>i10.5.5.5/32 2.2.2.2 0 100 0 100 i
*> 192.13.13.0/30 0.0.0.0 0 32768 ?
*>i192.23.23.0/30 2.2.2.2 0 100 0 ?
Route Distinguisher: 1:200 (default for vrf CINDY)
*> 10.4.4.4/32 192.14.14.2 0 0 200 i
*>i10.6.6.6/32 2.2.2.2 0 100 0 200 i
*> 192.14.14.0/30 0.0.0.0 0 32768 ?
*>i192.26.26.0/30 2.2.2.2 0 100 0 ?
TAURUS-Site_A#ping 10.5.5.5
Sending 5, 100-byte ICMP Echos to 10.5.5.5, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 456/696/972 ms
The prefix 10.5.5.5 (from Router TAURUS-Site_B) is receieved and pinged successfully from Router TAURUS-Site_A.
Cisco IOS IP and IP Routing Command Reference
Thanks! Nice explanation. I tried as override command under address family ipv4 and it worked.
Thanks very much , SunilKhanna
Nice explanation ,
This post helped me to revive the as-override feature. Thank you very much.
Mohsin Saleem
This is a good example indeed and it gives out a better understanding of as-override feature with the diagram with the PE and CE configuration.
Well done!
If I may suggest - for the next post, to have a sample ping and traceroute of similar setup , this time without the line as-overide included in the PE configuration as see what happens.
A video on the screenshot configuration could also be helpful in seeing the effect of removing one line .
Keep up the good work @SunilKhanna !
Hi all,
Does any one know on which IOS release was the support for as-override, without using a vrf, added?
I tested on a 1800 with IOS 12.4 and VRF is needed to be able to add the as-override command. Also tested on a 897 with IOS 15.4 and it worked fine without it.
Best regards.
This sentence must be a typo. The as-override feature works only for IPv4 and IPv6 address-families (for VRF, and global routing table for newer IOS releases). You cannot use it under VPNv4/v6 address families.
Good evening,
on your exemple, your are using public AS (100, 200,121)
I'm trying to do the same think with public AS and it doesn't work (with an ASR1000, there is no change with or without as-override)
Is it available on public AS ? or is it only available on private AS ?
Or is it a bug version ?
best regards.
./DWAM
I was actually doing some lab regarding this and you can actually make this work in IPv4 network as long as the source AS is the same as the receiving AS.
Sample below:
AS15---AS16---AS17
If you advertise networks of AS15 to AS16 then you configure AS-Override to AS17, nothing will happen. The AS-Path in AS17 will still look "16 15".
But if we change it to:
AS17---AS16---AS17
If we advertise the AS17(left) route to AS17(right) with AS-Override on AS16 facing the right-side AS17, the AS-Path will look as "16 16"
So looks like it is restricted in VPNv4 environment.
I was having this exact problem where as-override is only working when you connect two AS numbers that are overlapping with each other AS12 - AS13 - AS12. When i change AS12 - AS13 - AS14, the as-override is not working anymore.
