DevNet Networking
Engage with peers and Cisco experts about networking developer tools and resources.
Developer Sustainability Week Events
Build for Better Code Challenge
Cisco U. Spotlight Registration
>> View previously featured conversations <<
Browse the Community
Crosswork Automation Hub
Welcome to the Automation Hub—a collaborative space designed for the automation community to foster ...
Controllers
Community space to connect, share knowledge, and seek guidance on network controllers and related to...
Network Devices
Explore, inquire, and collaborate on network devices.
Activity in DevNet Networking
trex_subinterface_stats.py is no longer exists in latest master
got no module error, but when I looked master that it seems trex_subinterface_stats.py is no longer exists in latest master was it replaced by new functions?   linux-host0:/opt/trex/DevX-TRex-v23.11-v3.03-34/automation/trex_control_plane/interactive/...
maxli by Cisco Employee
  • 131 Views
  • 4 replies
Resolved! Module Error with pyang sample-xml-skeleton and IOS-XE YANG models
Hi, I am new to YANG/Netconf. Apologies in advance if there is an obvious answer to my question. I am using the Yang models of the https://github.com/YangModels/yang repositories, Python 3.9.2 and pyang 2.5.3 for the following: I am trying to get a f...
DrSchw0b by Level 1
  • 711 Views
  • 5 replies
DNA Center: Scheduled Discoveries
I have a set of successful discoveries in DNAC. I know that the devices discovered initially will continue to be updated every 25 minutes. What I'd like though, is to have DNAC regularly run the discoveries. I set up my discovery scopes to scan subne...
Problem with VoIP outgoing calls
Hello all, currently in the company I am at we have a few old models 7960 cisco series VoIP phones. They work almost perfectly fine with the exception that we can not make outgoing calls outside of the company for example calling someone's private ph...
Cisco router Speed test automation
Hi Cisco Community team,I have cisco ISR 4331 router on which i want to perform speed test automation so when speed goes down i should get email trigger.use cases.1. every hour speed test automation result on email2. If speed goes beyond x limit IT t...
How to push configuration to UPF dir /flash/
HiI am working on the automation of pushing configurations to UPF The configuration was committed to running config and it was working perfectly ok because it was not triggering the rebootNow there is a new scenarioAdd new interface for ipv6 and hten...
nisheeth by Level 1
  • 96 Views
  • 0 replies
Exasock - results in increased penetration latency
Has anyone encountered an increase in data penetration latency when using exasock for transparent acceleration on a k3p-s(X25) device?The background of the issue is as follows: I am using a third-party service's dynamic library to send network data t...
ysm by Level 1
  • 175 Views
  • 3 replies
Resolved! how to re-deploy with commit params from python
Hi all, Could you help me on the following .. in short, how can i do re-deploy with commit params from python .. i can commit a service with commit params from cli and python with success. for example : from cli : dd-rfs d1 commit commit-queue bypass...
erdemk by Level 1
  • 252 Views
  • 2 replies
Junos NED handling of leaf-list order
Hi,When updating leaf-list (ordered-by=user), the tags “insert” and “name” are generated in the RPC triggered to the device. This RPC is failing with latest Juniper versions.We checked with the Juniper team and they’re asking us to use “value” instea...
equinix by Level 1
  • 147 Views
  • 1 replies
