Networking
Collaborate with peers and Cisco on all aspects of your network, including Cisco Digital Network Architecture (DNA), routing, switching, and more.
Don't miss this Cisco Catalyst 8000 offer
Browse the Community
Cisco Catalyst Center
This community is for technical, feature, configuration and deployment questions. For production dep...
NFVIS Solutions
Join peers and Cisco experts to discuss Cisco’s Network Function Virtualization (NFV) products and s...
SD-WAN and Cloud Networking
Join this community to interact with your peers and Cisco about SD-WAN and all things related to sec...
Switching
ThousandEyes
Join us for information about our use cases, common troubleshooting, discussions, getting started gu...
Activity in Networking
Setting a GRE tunnels between a NAT to a public IP.
Hi everyone.. i have been looking through multiple posts on the forum for similar cases but have not found the answer Im looking for.. I've been primarily using this thread for guidance. https://community.cisco.com/t5/networking-knowledge-base/settin...
jonmo2578 by Level 1
  • 97 Views
  • 3 replies
redundancy in core layer
hi guys . i have a network with below topology. In the core layer, I want to have redundancy, which means that if the main core switch of my network has a problem, the backup switch will automatically enter the circuit. What method is there?
chpmotry by Level 1
  • 176 Views
  • 15 replies
L2VPN Over GRE
Hi I'm trying to extended a L2 segment using MPLS L2vpn over GRE. I am able to establish the tunnel and get ospf and mpls adjacency also the xconnect between the peer is up but my 2 test pc cant reach each other. This is my PE3 config.interface Gigab...
ASR1001-X Thruput only 750 meg Interfaces10G both sides -Circuit 10G
We have a Cisco ASR1001-X and it can only pass 750 megs of traffic thru it on a 10 Gig circuit. I looked at licensing levels and they seem correct. Anyone have any ideas of what I can look at? Both Lan and Wan interfaces are 10 gig and Wan is using S...
jroy777 by Level 1
  • 124 Views
  • 6 replies
BGP-LS ; how is BGP-LS data processed in BGP RIBS
Hello, I am working on collecting BGP-LS SAFI using BMP towards Cisco's opensource project Jalapeno. I have captured packets between RR and Jalapeno on each use case to observer where we see BGP-LS and where we DON'T see BGP-LS packets. few use cases...
Cisco 2960X and 9200L POE support for Paxton
Hi,We currently have a mix of Cisco switches from 2960s, 2960X and now the 9200L.  However we are having issues with our Paxton POE door controllers. The 2960s work with all of our Paxton ControllersThe 2960X up to hardware version 4 work with the Pa...
change Master Switch To slave in cisco Switch
Hello everyone, I have two cisco 3750 switches that are on stack with the below config Switch# Role Mac Address Priority State--------------------------------------------------------*3 Master 0017.5ae7.d500 1 Ready4 Member c062.6b8c.f200 1 Readyi wou...
joe5084 by Level 1
  • 75 Views
  • 2 replies
Resolved! Switch not reliably forwarding DHCP requests
Hi, hopefully this is the right place for this question. We have a switch stack of three 9300 switches running IOS XE that handle networking for the office area.  The office machines sit on a single vlan.  DHCP is provided by a Linux DHCP server sitt...
RyanMcC by Level 1
  • 9030 Views
  • 7 replies
Lost ARP Announcement Packet for Meraki MR30H Access Point
Hi,I have a setup with following  components.* Cisco - Meraki MSS120-8FP Gigabit Ethernet Switch* Cisco - Meraki MR30H Access Point (POE)* GRMS Device with LwIp Stack* 2 PC with Windows 10.* My PC (Windows) to pingWhen I try to ping the GRMS device t...
yldrmali by Level 1
  • 83 Views
  • 2 replies
Web Gui issues with C1121-4P router
I set up a C1121-4P router for a friend with int gig0/0/0 facing the ISP with ip address dhcp. int gig0/0/1 192.168.1.1/24. See attached sh run. Vanilla Configuration not much security or complexity. After a power reload the GUI "https://192.168.1.1/...
WebUi access for catalyst 3650
I am trying to access the WEB UI but it is giving me error:ERR_SSL_VERSION_OR_CIPHER_MISMATCHThe client and server don't support a common SSL protocol version or cipher suite.I am using client with Windows 2019 server OS..  Chrome Version 123.0.6312....
cbgrape by Level 1
  • 340 Views
  • 7 replies
Share your Expertise
Level up by answering questions in your area of expertise.
