If you have any features/improvement suggestions, let us know below.
I've a question concerning the setting of Overlay-mode on NDFC. The config-profile is the default setting once you have to bring-up a VXLAN fabric using NDFC; let's suppose that at a cert point, we want to introduce "security-group" with GPO and cont...
Failed to add site ACI. Cannot onboard same fabric on multiple Nexus Dashboard clusters. Fabric onboarded already on RecommendationsCheck fabric already onboarded on other cluster. its all first time setup.
Hi, all, i'm facing an issue while installing NDFC on a ESXI server. please check the following image.It's still not working even i execute the command "acs upgrade recover AppActivate".Anyone can help me on this? Thanks.
Introduction When working with Cisco devices (especially Nexus switches or routers with console access), you may encounter unexpected behavior if your password contains the sequence `~s`. This happens because Cisco interprets `~s` as a break signal —...
Hi all, for a customer we are going to implement a ACI multi-site adopting also NDI and not only NDO. The customer wants to have NDI and NDO on the same cluster of ND nodes. Considering that: - communication between ND and Fabric/APIC is via Data N...
Hello all, we have a 2 sites DC, and the DCI between them, consists of 2 DWDM 10Gbps links. In each site we have a Fabric composed by 2 Spine and several Leaf. We have a cluster of NDFC in one site and a UCS for NDI. My question is the following, it...
There is a detailed NSX-T on ACI design guide that details the use of the L3-Out via an SVI for peering with the NSX-T Tier0 Edge Node. I am looking for the equivalent reference design guide for peering with an NSX-T edge node from a Nexus VXLAN/EVPN...
My customer uses both Platform N9K and C9K. What they are looking for is to reduce complexity from a management perspective. I need to know the recommended solution I can provide which they can use as a single pain of glass. e.g. DCNM and DNAC Thanks
running ndfc 12.1.2.e. Is there any type of variable you can use in the name of the backup file that gives the date-year-time?.From what I can tell you config a weekly sftp scheduled backup with the name of ndfcweekly.gz.tar, that is the name it wil...
This session introduces the use of a VXLAN EVPN gateway functionality in an ACI fabric to establish native Layer 2 and Layer 3 connectivity between two different types of VXLAN fabrics (in this session- NDFC VXLAN and ACI iVXLAN). The session covers ...
Hello I'm trying to connect to a dcloud NDFC session using anyconnect and even web browser but always Login Failed !!!!! Any idea?
HelloI am trying to add a site to NDFC and i get the error messagemessage: Site Auto detection failed, Please make sure controller is reachable and credentials are correctFrom the nexus 9k switch i can ping both NDFC on the management and Data interf...
Hi everyone, i have a pair of questions about the next scenario: - VXLAN EVPN Fabric Deployment from NDFC with two sites interconnected back to back between spines - OOB Mgmt Network deployed with Nexus in NX-OS mode - ND nodes deployed in one side...
Nexus Dashboard v3.2.1iFabric Controller v12.2.2.241Under the default admin login, I'm able to access Fabric Controller --> Manage --> Zoning and perform zoning without issue. When logged in via TACACS (ISE) with a network-admin role assigned, I get ...
Hello, I am having an issue with NDFC. When I create a "VXLAN EVPN Multi-Site" fabric, and then nest my "Data Center VXLAN EVPN" fabric underneath it... NDFC pushes out the expected configuration (config needed on the BGWs for Multi-Site to work) ......
Subject | Author | Posted |
04-25-2025 04:30 AM | ||
04-16-2025 03:10 AM | ||
04-11-2025 09:45 AM | ||
04-07-2025 10:17 AM | ||
04-03-2025 02:14 PM |
