Hello everyone,
Our organization had issue with the primary ND cluster and needed to reinstall it.
Unfortunately we missed to remove the "child" clusters in the Multi-Cluster setup.
Now after the new primary ND Cluster is up and running I tried to connect the other non-primary cluster but I got the message: Cluster already part of federation. On the secondary cluster I still see the primary one and cannot remove the information about it from the secondary.
Do you know if there is a way to clear, or reset, the Multi-Cluster information on the secondary ND cluster, so I can claim it again from the Primary?
