Starting
Hi can I get some help to protect my router with family shield?
Sheraz.Salim
Access your router's admin panel. This is typically done by entering your router's IP address (often 192.168.0.1 or 192.168.1.1) in a web browser.
Log in using your router's admin credentials.
Locate the DNS settings. This may be under a section like "WAN", "Internet", or "Network".
Replace your current DNS server addresses with the FamilyShield DNS addresses:
Primary DNS: 208.67.222.123
Secondary DNS: 208.67.220.123
Save the changes and reboot your router if prompted.
After configuring, test your settings by visiting https://welcome.opendns.com/. You should see a "Welcome to OpenDNS!" message if successful.
please do not forget to rate.
reham1
What is the make and model of the router that you are using?
