Optics and Optical Networking
Engage with peer and Cisco experts about pluggable optics (Optics) and optical transport networks (Optical Networking).
Learn how to make your network more efficient when you transition to Routed Optical Network.
Resolved! C9400
We are going to buy a Cisco C9400 with C9400X-SUP-2XL supervisor which has 4 10/25G ports and 3 40/100G ports.we want to use the three ports with 100G as 10G only, so i wonder if it's possible and what do we need exactly ? to use SFP+ transeiver modu...
Hello,I'm trying to connect N9K-C93180YC-FX3 to Palo Alto PA-1410. I have transceivers listed below:CISCO: SFP-10/25G-CSR-S.PA: PAN-SFP-PLUS-SRIs there a solution to make them work? I'm trying without any results. I'm trying to establish 10 Gbps conn...
k-staniak by Level 1
  • 239 Views
  • 3 replies
We have been using OEM sfps for a long time with C2960 series without a problem but we cuurently switch to a C1000 series switch and apperantly this series does not support the allow-unsupported-transceiver command. Does anybody know  a way to use ot...
Acar by Level 1
  • 5677 Views
  • 3 replies
                  I'm sure this has been covered on here before but just got a new laptop with Windows 7 and cannot get CTC to work, CTP is fine and works much better under Windows 7 because it can make use of the additional memory but CTC just hangs...
We have a Cisco C9200L-48P-4X and we would like to connect a SFP+ of 10Gb (that from the specs, is a fixed uplink) to a server that has a 10Gb port. We are using a Cisco SFP-H10GB-CU5M Compatible 5m 10G SFP+ to SFP+ Direct Attach Cable Twinax - 10GbE...
