Resolved! SFP-10G-LR and ASR1002
Hi all,two queries I cannot find an answer for: 1. is the SFP-10G-LR compatible with the ASR 1002 router? 2. And if so, can it run at 1gig or is it just fixed at 10gig? Thanks, Paul
I have a Cisco 3850 24 that I am trying to connect with a Cisco 6506 E through a WS-6716-10GE module using a x2-10g-lx4 GBIC. From the cisco module compatibility chart the have the same wavelength but i can't get a link light. Are these modules com...
I need to connect SFP+ server with Cisco SFP+ switch. They are very close to each other so I need just 2 meters cable. I can do this using two cables: eitherCisco SFP-10G-AOC2M Active Optical Cable assemblyorCisco SFP-H10GB-CU2M Twinax cable, passive...
Dear All,Is there any requirement to reload the card when changing from LAN PHY to WAN PHY?ASR 9001A9K-MPA-4X10GE Regards, Pok.
Hello,I need to connect a fiber between a WS-X6708-10GE module of a 6500-e chassis to a third-party Firewall. The Firewall has 10G SFP+ SR transceiver. I need to connect the two devices through a 10 Gbps link. I'm not sure if I can connect a GBIC to ...
Hi Everyone...I have a few days testing with the ME-4624 ONT, to provide internet to its LAN. This device is connected to a functional ME 4605 OLT , and the needed route to provide internet to the equipment its already configured and tested. I also c...
I have a switch with all four 10g optical links on a port channel showing -40.0 dBm Optical Receive Power. I believe this means it's not receiving a signal at all. I don't have physical access to the switch nor the device the port channel is connecti...
Dearshave a good dayi have 75 IP camera on a fence, the distance between every two cam is 40 meters.what is the best solution to connect them to the NVRs?
Hi,Is GLC-SX-MM supported in CGS-2520-16S-8PC 100BASE-FX SFP ports ? It's not listed in compatibility table, GLC-SX-MM-RDG is listed as supported on gigabit SFP ports only.
Hi At one of the plant we have C2960S-24TS_L switches are provided with multi mode transceiver but the Optical Cable available at site is single mode Optical fiber. So i procured a single mode transceiver. But I came to know that we have to some con...
GLC-SX-MMD reach of 300m on 50/125 µm MMF
On our product, the SFP cages are hooked up directly to the SerDes pins coming off the switch. We're trying to understand the consequences of doing this vs. say having an SGMII interface hooked to that cage. There appear to be both SGMII and SerDe...
need help for fiber patch cable cord type selection based on different types of SFP connectors , is there any on-line links or any document that will be helpful..
Hi All,On the Nexus 6004 series, does anybody know how to see the light levels for the optics.I am using the command: show interface ethernet 2/5/4 transceiver details which outputs:Ethernet2/5/4 transceiver is present type is QSFP-40G-CSR4 ...
we have ons 15454m6 version 9.8.0 which is the bugs CSCuh76017 & CSCuj97107.If we upgrade to 9.8.1.2 , our CPO (9.8.0.33) can not support the NE version. Any support for us ?Could you help to provide CPO which support NE version 9.8.1.2 or provide NE...
Subject | Author | Posted |
03-27-2024 12:16 AM | ||
03-27-2024 12:09 AM | ||
09-10-2023 08:07 AM | ||
08-03-2023 03:20 AM | ||
06-14-2023 06:52 AM |
