ASR9903 3+1 power redundancy
gtimm92700
does ASR9903 support 3+1 power redundancy when connected to low voltage (100-120V) input, what if two inputs fail?
balaji.bandi
Power redundancy works based on the usage and consumption of the device.
If the 2 PSU Fails - 3rd can able to supply same input power required for device, then device work as expected. if it was over loaded, some of the Modules may go offline due to insuffcient power.
BB
