11-17-2017 01:00 AM - edited 03-01-2019 08:40 AM
Hi All,
I am connecting 2 pair of NEXUS 9500 using vPC DCI with HSRP. I can't seem to find the detail in any document on how to set this exactly. Right now, I am a bit confusing on the VLAN priority that should be set on each pair of nexus switch. Can anyone guide me what should be the correct method to set VLAN priority on these 4 switches.
My guess is to have one pair of nexus with priority 0 and another pair with priority 4096. Or should all 4 switches have the same priority?
## I only have these 2 pair of nexus switches acting as core on each side of DC ## Other switches connecting to nexus switch are typical Cisco IOS switches
11-17-2017 03:40 AM
11-17-2017 03:47 AM
11-17-2017 08:44 AM - edited 11-17-2017 08:50 AM
So if I understand you correctly your going to extend the vpc over the DCI?
If you go to page 13 in this link is this what you are trying to achieve? Also starting on page 58 shows the configuration.
https://www.cisco.com/c/dam/en/us/td/docs/switches/datacenter/sw/design/vpc_design/vpc_best_practices_design_guide.pdf
11-17-2017 08:13 PM
Hi Rick1776
Thank you for helping. After re-reading this doc once again I realize what it might be.
Reference in the doc is on page 14 and page 61 would be what I am trying to archive.
I found in the doc said: (Page 62)
11-17-2017 08:41 PM
11-17-2017 08:48 PM
11-17-2017 09:14 PM
Correct.
