08-30-2023 01:15 AM
Hi team,
I have a problem with a N3K-C3172TQ-XL, when I try to perform a copy tftp: bootflash: I get the following error:
SWPSJCPDCPDN3A1# copy tftp: bootflash:
Enter source filename: nxos.9.3.12.bin
Enter vrf (If no input, current vrf 'default' is considered):
Enter hostname for the tftp server: 10.140.8.86
Trying to connect to tftp server......
TFTP get operation failed:Permission denied
SWPSJCPDN3A1#
What can this be due to?
Thanks & Best Regards,
Juanmi
08-30-2023 04:52 AM - edited 08-30-2023 04:53 AM
TFTP get operation failed:Permission denied - access issue or the file in the right location ( most of the time the file expect to be in root folder)
check any ACL in the TFTP check is the Nexus IP allowed ?
check is the TFTP working or not copy the config to TFTP see if that works ?
08-30-2023 11:48 PM
Hi Balaji.bandi,
I just ran the following test, and it worked correctly.
SWPSJCPDN3A1# copy tftp: volatile:
Enter source filename: SWPSJCPDN3A1-running-config
Connection to Server Established.
TFTP get operation was successful
Copy complete, now saving to disk (please wait)...
Copy complete.
SWPSJCPDN3A1# dir volatile:
17459 Aug 31 07:41:22 2023 SWPSJCPDN3A1-running-config
0 Aug 11 23:28:48 2022 nginx_logflag
60 Aug 11 23:28:38 2022 virtual-instance/
Usage for volatile://sup-local
20480 bytes used
629125120 bytes free
629145600 bytes total
SWPSJCPDN3A1#
There seems to be some kind of write permissions problem in the Bootflash:, which does not allow copying files.
Any idea why?
Juanmi
