11-15-2017 04:01 PM - edited 03-01-2019 08:40 AM
Hi there,
We have a project to change the existing configuration on the existing N9K VPC peers. I need to configure an interface VLAN 999 and enable OSPF p2p on one N9K. And configure an interface VLAN 1002, enable OSPF p2p on another N9K. There is VPC peer link between two N9Ks and allow VLAN 999 and 1002 to pass through. I was wondering can I configure different SVI on the VPC peer devices?
Thanks in advance,
Eric
Solved! Go to Solution.
11-16-2017 02:21 PM
They would only need to match if they are going to be a VPC VLAN. If they are standard L3 routes you don't have to worry about that.
11-15-2017 05:15 PM
11-15-2017 07:28 PM
11-15-2017 08:16 PM
11-15-2017 08:23 PM
11-15-2017 09:12 PM
11-15-2017 09:30 PM
Is this what you are trying to achieve?
11-15-2017 09:54 PM
Thanks Rick,
My colleague told me we cannot configure two different interface VLAN on the VPC peer. It should be the same interface VLAN on two N9Ks. Otherwise, the N9K will shutdown the interface VLAN. Could you confirm that?
We have a plan to let all traffic from the ASR to pass through the firewall. So i assign the interface on N9k-1 to vlan 998. and configure a trunk between n9k-1 and the FW, and only allow vlan 998 and 999 on the trunk. then bridge VLAN 998 and 999 on the FW. After that, create interface vlan 999 and assign a IP address which is in the same ip subnet with the interface on the ASR. So the all traffic will be forwarded to the FW. Also OSPF P2P will be established between the interface on the ASR and the SVI on the N9K-1.
11-15-2017 10:38 PM
Let me do some research.
11-15-2017 11:24 PM
11-16-2017 07:39 AM
Thanks Rick, based on the document, L3-A to Nexus-A peering is always supported for L2/L3. If L3-A also directly connect to Nexus-B. Is L3-B to Nexus-B supported for L3?
11-16-2017 08:15 AM
11-16-2017 09:58 AM
11-16-2017 10:18 AM
11-16-2017 12:53 PM
