11-07-2012 12:27 PM - edited 03-03-2019 06:50 AM
It has a dedicated link to 8Mb, the connection to the carrier is RJ45 which connects to a 2901 router that acts as a gateway for the LAN, what is required is to be logically divided into two internet link to have half for specific applications for the company and the other half to users.
What options do you recommend?
Solved! Go to Solution.
11-07-2012 06:17 PM
you could use QoS policies to police the MAX available bandwidth per group of apps or users
see the bellow link might help you to figure out the idea and how to use HQoS in your case
where you can have one parant policy to share the interface to 8M and two child polices police/shape the relevant classes to 4M each
https://supportforums.cisco.com/docs/DOC-8373
hope this help
11-07-2012 06:17 PM
hope this help
11-08-2012 08:21 AM
Hi Marwanshawi
Currently the network is flat, is it advisable to create two separate VLAN for traffic? and to apply QoS policies
Thank you
11-08-2012 11:32 AM
Hi Marwanshawi
According to the document you recommended,
I have the possible configuration:
class-map match-all HOTEL_ADMON
match access-group 100
class-map match-all GUEST
match access-group 200
access-list 100 permit 192.168.10.0 0.0.0.255
access-list 200 permit 192.168.20.0 0.0.0.255
policy-map DIV
class-map HOTEL_ADMON
bandwidth percent 50
class-map GUEST
class class-default
shape average 10000000
int gi 0/0
service-policy output DIV
Would it be enough?
