Duplicate frame relay maps.
jasonbegley
I have router A with 2 serial frame relays, dlci 101 and 102. I have remote router B with 1 serial frame relay dlci 150. I was planning on moving router B from frame leg #2 dlci 102 to frame leg #1 on dlci 101. Everything is already configured on telco side. I see dlci 101 and 102 on router B and I see dlci 150 on both frame legs on router A. Can I just add frame maps on both routers for both dlci's and then change routes, or would the redundant paths cause problems?
n2-goes
If the pvc between 102 and 150 is already created, you should be able to add the frame-relay map to your router. By adding the new map, you effectively have 2 path between Rtr A and Rtr B.
Do not forget, you are paying for both until you cancel the old pvc.
HTH,
Nadine.
