Frame Relay CIR verification
midgar31
my question is, how i can see the actual BW or CIR in a frame relay circuit?
thisisshanky
Level 11
Level 11
Give a "show frame-relay map". At the end of each IP next-hop to DLCI mapping, you will see the actual CIR of the link.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
vkasacavage
Depending on the way the provider has implemented frame relay, you may or may not be able to see such things. Debug frame-relay lmi may show you the info you are looking for
