help for adsl and vlan
MohsenMostafa
hello, im new to ccna .
please any expert help me in this scenario,
router 1721 with one wic-1adsl ,i have adsl connection with irb static ip.
the router connect with managed switch through a trunk port.
the switch has 2 vlans one for the static IPs and the other for private lan.
i need the private lan to be able to go to internet please any ideas.
the router configuration is as follows:
Building configuration...
Current configuration : 1272 bytes
! Last configuration change at 16:50:18 pc Fri May 10 2013 by admin
version 12.2
hostname BELCO
boot system tftp c1700-k9o3sy7-mz.122-15.T17.bin 62.x.x.7x
logging queue-limit 100
username admin privilege 15 password 0 HES2010
clock timezone pc 0
ip subnet-zero
ip cef
bridge irb
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 0/35
  encapsulation aal5snap
dsl operating-mode auto
bridge-group 1
interface ATM1
no ip address
shutdown
interface FastEthernet0
no ip address
speed auto
interface FastEthernet0.1
description LAN
encapsulation dot1Q 1 native
ip address 192.168.1.10 255.255.255.0
interface FastEthernet0.2
description WAN
encapsulation dot1Q 2
ip address 62.x.x.7x 255.255.255.248
interface BVI1
mac-address 0000.0cc9.fa98
ip address 10.186.10.106 255.255.255.252
ip classless
ip route 0.0.0.0 0.0.0.0 BVI1
ip http server
ip http authentication local
bridge 1 protocol ieee
bridge 1 route ip
line con 0
speed 115200
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet
no scheduler allocate
end
so vlan2 can go to internet because it has the same subnet with provider but vlan 1 canot go internet.
so how i can make all vlans go internet(the router has only 1 fastethernet port)
and i tried theses ......
interface fa0.1
ip nat inside
interface fa0.2
ip nat outside
ip access-list extended MY_NAT
permit ip 192.168.1.0 0.0.0.255 any
ip nat inside source list MY_NAT interface fa0.2 overload
ip route 0.0.0.0 0.0.0.0 [YOUR Default Gateway IP here]
no ip route 0.0.0.0 0.0.0.0 BVI1
but didnt work
someone told me i need loopback interface but dont know how
thanks in advanced for any help.
Luke Oxley
MohsenMostafa,
Thanks for the post, I assume that you're still having the same issues and need assistance. I've had a look over your configuration for you and can see some big gaps in what needs to happen. I'm also giving you this advice based on the assumption that you can successfully ping 8.8.8.8 sourced from BVI1 and that you can ping 8.8.8.8 from one of your static public addresses in VLAN2.
The reason that VLAN1 traffic cannot access the internet is because it is a private address range, and what do private addresses rely on to access the internet? NAT. Your configuration is not setup correctly to NAT. I can see from what you've tried you have made a good attempt to get this working, but a few things are just slightly amiss.
To configure NAT for VLAN1 in your scenario you need to follow the steps below:
1. Create an access control list defining the traffic you wish to NAT.
access-list 100 permit ip 192.168.1.0 255.255.255.0 any
2. Specify the logical role of your interfaces in question, for example, BVI1 is your public facing interface OR "outside" interface and FastEthernet0.1 is your private/LAN facing interface OR "inside".
interface BVI1
 ip nat outside
 ip nat inside
3. Lastly, you need to create the NAT statement that ties all of this together.
ip nat inside source list 100 interface bvi1 overload
Everything else in your configuration looks spot on and ready to go. Please make these changes advised above and test by attempting to ping 8.8.8.8 from a machine on VLAN1. Please also ensure this test machine has an IP address in the 192.168.1.0 address space and has its default gateway set to the sub-interface of the router at 192.168.1.10.
Let me know how you get along, we can take further troubleshooting steps if you are still having issues afterwards. I look forward to your response.
Luke
Things to bear in mind:
- The word "overload" in the NAT statement allows the function of PAT'ing. This means that more than one host behind the router can access the internet otherwise known as a many:1 NAT as it allows multiple private IP addresses to all access the internet by sharing the same public IP address.
- Whoever told you that you needed a loopback interface in order to NAT traffic from VLAN1 in your example was very much incorrect.
Please rate helpful posts and mark correct answers.
