NAT using different port numbers
raymond.burcham
I have a situation where we are using PAT, but have an application that connects from inside to outside but the return connection uses a different port number. All connections work except this one application.
1) Is the anyway of doing this with PAT
2) If I take the overload command out will, I think will be using NAT and does
NAT care which port the return connection uses. Does it look at ports at all just map address to address.
interface Loopback0
ip address 139.170.251.253 255.255.255.128
interface FastEthernet0/0
description IRM
ip address 10.10.10.1 255.255.255.128
ip nat inside
duplex auto
speed auto
interface Serial0/0
description to Dartmouth
ip unnumbered Loopback0
ip nat outside
encapsulation ppp
no fair-queue
no cdp enable
interface FastEthernet0/1
description RES
ip address 139.170.251.1 255.255.255.128
duplex auto
speed auto
router rip
redistribute connected
network 10.0.0.0
network 139.170.0.0
ip nat pool Dartmouth 139.170.251.129 139.170.251.248 netmask 255.255.255.128
ip nat inside source list 10 pool Dartmouth overload
ip nat inside source static 10.14.12.2 129.170.251.254
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/0
ip route 10.14.0.0 255.255.128.0 10.10.10.2
ip http server
ip pim bidir-enable
access-list 10 deny 10.14.12.2
access-list 10 permit 10.14.0.0 0.0.127.255
tepatel
If no "overload" then its simple NAT which will not care for ports. Its inside to outside ip address translation. Here is the link for more on that
http://www.cisco.com/warp/public/556/nat-cisco.shtml
Now for PAT (using overload) to work, the outside to inside reply should be on the same source port number otherwise router will not map those ports correctly.
tepatel
Removing the overload did fix their problem.
/ray
