05-18-2004 07:44 AM - edited 03-02-2019 03:47 PM
Do anybody use the Cisco NFC to collect Netflow exported data ?
What is your feed Back of this software ?
- In term of display
- In term of filtering
Do you recommand it ?
Thanks in advance for your reply.
05-25-2004 04:50 PM
It works pretty well if you setup and configure it properly and then use it according to the docs.
05-26-2004 01:27 PM
I evaluated it, but I was looking for something with a bit more capabilities in terms of reporting. The NFC does a great job of collecting, but Cisco is just starting to really delve into reporting with it. I prefer NetQoS's ReporterAnalyzer product, but there are a lot of tools out there that do a good job of reporting. Here is a list of other products that can do NetFlow reporting http://www.switch.ch/tf-tant/floma/software.html.
05-26-2004 02:32 PM
If you're "open" to open source and have access to Linux, try ntop at www.ntop.org. There may even be a Windows-based binary there.
