Ongoing TFTP requests from several Cat 3500XL switches
Mel Popple
I'm experiencing repeated tftp requests for config files from several of the Cat 3500XL switches on the network. These are clustered with standby cluster
commanders activated.
All switches are running IOS (tm) C3500XL Software (C3500XL-C3H2S-M), Version 12.0(5)WC3b.
The following is the the output from the TFTP server that is running on my laptop:
Connection recieved from ***.**.121.251 on port 1765
Read request for file <network-confg>. Mode octet
Error : EACCESS. CreateFile returns 2: <The system cannot find the file specified.>
That is repeated for a couple of times and then the following:
Connection recieved from ***.**.121.251 on port 3179
Read request for file <cisconet.cfg>. Mode octet
And finally changes to this:
Connection recieved from ***.**.121.251 on port 4430
Read request for file <group48-d1-confg>. Mode octet
Non of the switches have anything in their start configs that tell them to look to a tftp server for any of their configs. Any ideas
Mel
Here is the Show Version output:
GROUP48-D1#sh ver
IOS (tm) C3500XL Software (C3500XL-C3H2S-M), Version 12.0(5)WC3b, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Fri 15-Feb-02 10:51 by antonino
Image text-base: 0x00003000, data-base: 0x00337600
ROM: Bootstrap program is C3500XL boot loader
GROUP48-D1 uptime is 19 hours, 15 minutes
System image file is "flash:c3500XL-c3h2s-mz.120-5.WC3b.bin"
cisco WS-C3548-XL (PowerPC403) processor (revision 0x01) with 16384K/1024K bytes of memory.
Processor board ID FAA0436I0E3, with hardware revision 0x00
Last reset from power-on
Processor is running Enterprise Edition Software
Cluster command switch capable
Cluster member switch capable
48 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:03:6B:97:4A:80
Motherboard assembly number: 73-3903-04
Motherboard serial number: *************
Power supply serial number: NONE
Model revision number: A0
Motherboard revision number: B0
Model number: WS-C3548-XL-EN
System serial number: **************
Configuration register is 0xF
wkumari
Try doing:
conf t
no service config
end
I sounds like you have service config on (it is the default in some versions) and the switches are trying to TFTP their configs....
wkumari
Try doing:
conf t
no service config
end
