Please help source a +24V DC Powered Switch
allongsound
Hi All,
I am desperately looking for a +24V DC powered switch.
It needs to be
24V DC input
Managed, with RSTP
48 ports if possible, although i can cope with 2x 24 ports if needed.
Any help would be greatly appreciated.
Do you want an industrial switch? something like the Cisco IE 2000 range
I don't think it can be done with the IE2000 series, but you can with the IE3000 series (search for 24VDC).  But as for getting 48 ports ... you'll need a lot of them.
http://www.cisco.com/c/en/us/products/collateral/switches/industrial-ethernet-3000-series-switches/data_sheet_c78-440930.html
Only having 24VDC is very limiting.  If you could step up to 48VDC then you have lots of options (Cisco 3650 with DC supply, Cisco 3850 with DC supply, etc).
Personally - use a power regulator or get an electrical engineer to make you a 48VDC power supply.  It will be much cheaper since you can use more generic switches like the 3650, rather than lots of expensive IE3000's.
Here is an interesting option.  PWR-IE65W-PC-DC= says it can take 24VDC in and spit out 54VDC.
You would have to check out the current ratings, but this module might work with a 3650 ...
