11-04-2002 02:39 AM - edited 03-02-2019 02:36 AM
What is the equivalent IOS switch command for the Catalyst 6509 CAT OS <set port security> command.
on other IOS switches like the 3550 series there is a command - switchport port-security. i need to know the command on CAT6509
Solved! Go to Solution.
11-04-2002 07:36 AM
The following URL covers setting up port security on a 6500 running Native (These commands were introduced in 12.1(13)E):
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/12_1e/swconfig/port_sec.htm
