Hi all
This is a strange one.
I set up a site to site VPN 837>3005 concentrator wihout problems. The tunnel is up and running fine it seems, as i can always ping or telnet the remote (837) routers LAN ip, that should prove that the tunnel works.
Every X mins the connectivity stops, i.e unable to ping any host on the remote LAN (router LAN addr always OK to ping).
After 10 mins or so it starts working again by itself.
2 other ways is to ping 3005's WAN addr from remote LAN PC, or issue "clear arp" on the 837.
When it hangs the "show arp" shows arp table as it should.
Ping from 837 to any addr on LAN is still OK . I tried to lower the ARP timeout to 60 sec without fixing the problem.
Any brilliant ideas out there ?
