Using Cisco Documentation CD on a Win2K Pro Machine
namso2
I've uninstalled and re-installed several times to no avail. When I attempt to launch the Documentation CD, I get "Page has expired" or something to that effect. I use both Netscape and IE.
I'm able to use the same CD on a different Win2K Pro box, but it's a hassle to not be able to use my own laptop.
PS: I realize I can get the same documentation on CCO, but I want to be able to access documents offline.
liviu.gheorghe
An easy workaround is to rename the expired.htm page into home.htm and your problem is solved.
This is the method I use.
Regards, LG
*** Please Rate All Helpful Responses ***
liviu.gheorghe
Regards, LG
That worked. I just need to clarify, for other readers: rename expired.htm to expired2.htm, and home.htm to expired.htm.
hello ,
i also want Cisco Documentation CD for Home use on my own computer,
what the procedure to got the Documenation CD from Cisco
tell me mirfanaslam@hotmail.com
thankz
irfan
