Issue installing Duo on AIX 7.2
JSantos12
When running
./configure --with-pam --prefix=/usr && make && sudo make install
The following output from the command is as follows
checking for a BSD-compatible install... autotools/install-sh -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... autotools/install-sh -c -d
checking for gawk... no
checking for mawk... no
checking for nawk... nawk
checking whether make sets $(MAKE)... yes
checking whether make supports nested variables... yes
checking whether to enable maintainer-specific portions of Makefiles... no
checking build system type... powerpc-ibm-aix7.2.0.0
checking host system type... powerpc-ibm-aix7.2.0.0
configure: autobuild project... duo_unix
configure: autobuild revision... 2.0.1
configure: autobuild hostname... server
configure: autobuild timestamp... 20230717T162057Z
checking for style of include used by make... GNU
checking for gcc... no
checking for cc... cc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... no
checking whether cc accepts -g... yes
checking for cc option to accept ISO C89... -qlanglvl=ansi
checking dependency style of cc -qlanglvl=ansi... none
checking how to run the C preprocessor... cc -qlanglvl=ansi -E
checking for grep that handles long lines and -e... /usr/bin/grep
checking for egrep... /usr/bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking minix/config.h usability... no
checking minix/config.h presence... no
checking for minix/config.h... no
checking whether it is safe to define __EXTENSIONS__... yes
checking whether we are using the GNU C compiler... (cached) no
checking whether cc accepts -g... (cached) yes
checking for cc option to accept ISO C89... (cached) -qlanglvl=ansi
checking dependency style of cc -qlanglvl=ansi... (cached) none
checking whether cc -qlanglvl=ansi and cc understand -c and -o together... yes
checking how to print strings... print -r
checking for a sed that does not truncate output... /usr/bin/sed
checking for fgrep... /usr/bin/grep -F
checking for non-GNU ld... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... no
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 786432
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... no
checking how to convert powerpc-ibm-aix7.2.0.0 file names to powerpc-ibm-aix7.2.0.0 format... func_convert_file_noop
checking how to convert powerpc-ibm-aix7.2.0.0 file names to toolchain format... func_convert_file_noop
checking for /usr/bin/ld option to reload object files... -r
checking for objdump... no
checking how to recognize dependent libraries... pass_all
checking for dlltool... no
checking how to associate runtime and link libraries... print -r --
checking for ar... ar
checking for archiver @FILE support... no
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from cc -qlanglvl=ansi object... ok
checking for sysroot... no
checking for mt... mt
checking if mt is a manifest tool... no
checking for dlfcn.h... yes
checking for objdir... .libs
checking for cc -qlanglvl=ansi option to produce PIC...  -DPIC
checking if cc -qlanglvl=ansi PIC flag  -DPIC works... yes
checking if cc -qlanglvl=ansi static flag -bnso -bI:/lib/syscalls.exp works... no
checking if cc -qlanglvl=ansi supports -c -o file.o... yes
checking if cc -qlanglvl=ansi supports -c -o file.o... (cached) yes
checking whether the cc -qlanglvl=ansi linker (/usr/bin/ld) supports shared libraries... yes
checking dynamic linker characteristics... aix7.2.0.0 ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... no
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... no
checking if -fstack-protector and -fstack-protector-all are supported.... yes
configure: -fstack-protector disabled on AIX
checking whether byte ordering is bigendian... yes
checking for an ANSI C-conforming const... yes
checking for int64_t... no
checking for ANSI C header files... (cached) yes
checking for inttypes.h... (cached) yes
checking limits.h usability... yes
checking limits.h presence... yes
checking for limits.h... yes
checking for memory.h... (cached) yes
checking for stdint.h... (cached) yes
checking for stdlib.h... (cached) yes
checking for string.h... (cached) yes
checking for unistd.h... (cached) yes
checking for pkg-config... no
checking for openssl/ssl.h in /usr/local/ssl... no
checking for openssl/ssl.h in /usr/lib/ssl... no
checking for openssl/ssl.h in /usr/ssl... no
checking for openssl/ssl.h in /usr/pkg... no
checking for openssl/ssl.h in /usr/local... no
checking for openssl/ssl.h in /usr... yes
checking whether compiling and linking against OpenSSL works... no
configure: error: in `/opt/duo_unix-2.0.1':
configure: error: OpenSSL not found
See `config.log' for more details
It looks like it's having an issue with OpenSSL but when I check, it has the right version (openssl version -a) but it still errors out.
I have tried this as well with no success (https://help.duo.com/s/article/4497?language=en_US)
./configure --with-pam --prefix=/usr --with-openssl=/usr
DuoKristina
Try...
./configure CFLAGS="-nostdinc -I/usr/include" --with-pam --prefix=/usr --with-openssl=/usr
Duo, not DUO.
JSantos12
Unfortunately, that failed as well.  We will be looking in to installing gcc though.  Hoping it may help
configure: autobuild hostname... Server
configure: autobuild timestamp... 20230818T175536Z
checking whether the C compiler works... no
configure: error: C compiler cannot create executables
