Does the iw9167e wireless AP comply with the SIL2 Secure Rate Wireless?If not, which Cisco AP products are certified?
A simple question....If I just knew where to find the answer:Doing MAC authentication on an 5520 WLC, I can see the MAC addresses accepted by the WLC if I issue the command:"sho macfilter summary"Can anyone tell me the equivalent command on a 9800 (y...
Hi community!I posted about some 2702i in autonomous mode, degrading throughput after some time - see post: Autonomous Mode Failing on Aironet 2702i-z-k9 - Cisco CommunityLast days I got a WLC 2504 and other 2702i access points (in controlled - LWAP...
Hello we have a local 9120axi AP with a 9800LC WLC that seems to be losing connection. The AP is in flex connect, all config looks fine: AdvancedCountry CodeUS Multiple CountriesUSStatistics Timer180CAPWAP MTU1485AP Link LatencyEnabledAP PMK Propaga...
We have wireless and wired devices that uses Bonjour (mDNS) service to discover each other. I need to configure both wired and wireless devices in the same VLAN . We have Cisco WLC 5520 and APs that support flexconnect feature. I need to configure AP...
Hello friends, I have a virtual WLC 9800 running version 17.6.5. A client is unable to connect from a specific PC, but can connect successfully from other devices. I have verified the credentials, and they are correct. The specific PC can connect nor...
We want to utilise the 4 ports on the Cisco C9800-L-F-K9 to connect APs - and SVI interface on the WLC have been created on trunk TenGigabitEthernet0/1/0 with wlan 5 and 100 and - access port vlan 5 on TwoGigabitEthernet0/0/0 should these two/4 ports...
Hello, I have a WLC9800 with 9115 APs.For clients, I have a Vlan (100) mapped to an ssid. I want to add another vlan (102) mapped to the same ssid.I have added the vlan 102 (configuration, layer2, add vlan), i have created a vlan group and added both...
I have a 9800-CL in an SD-WAN setup. I have multiple sites that have the same Vlans at each site to make it easier to manage and remember.Ex:NorthSite: data-4, voice-5, wifi-6SouthSite: data-4, voice-5, wifi-6etc...My current WLC configuration has on...
Hello ,We are having problem with one AP to join the WLC , all others successfully the controlle. the console output is :[*03/19/2024 09:08:50.0003] CAPWAP State: DTLS Setup[*03/19/2024 09:08:50.0035] dtls_process_packet: DTLS Error: 1040[*03/19/2024...
We have a chicken & egg situation where ISE requires a user's login and the presence of a user cert from AD before the user can be permitted to connect to the corporate wifi. But the user needs to connect to wifi to get the cert. One solution i have ...
Recently swapped our 3802i APs for all C9130AXI to get the WiFi 6 capability. Have noticed very poor performance overall. Only change has been with the APs, nothing else. The controller remained to be an AIR 3504 and the switch is a Catalyst 3850 UPo...
I have a WLC with 11 registered access points I tried to integrate a new equipment, but I see that I already have my 37 licenses in use. Can you guide me and let me know what this is due to?there is a way to release licenses from the WEB portal or...
Hi,If Radius server gets updated with the new IP address, will current users remain connected or will they need to reconnect?I am asking for both AireOS and 9800 WLC.
Hi,I want to know below;1. The first character what we can not use on Aironet 2700 "hostname".2. The characters what we can not use on Aironet 2700 "hostname".
Subject | Author | Posted |
04-23-2024 07:19 PM | ||
04-12-2024 05:27 AM | ||
04-10-2024 01:01 PM | ||
04-05-2024 06:44 PM | ||
04-04-2024 03:18 AM |
User | Count |
14 | |
4 | |
3 | |
2 | |
2 |
