Cisco ISE/AnyConnect/Duo SAML Integration
dpereziii
I’m familiar with the recommended integration as seen below:
Is there a way to perform a SAML authentication with the AnyConnect mobility client for the interactive prompt and then the ISE radius?
LelisC
I have the same need to implement this, did you have any progress with this?
