Routers - Small Business
Routers tailored for small businesses, providing efficient and reliable connectivity for your growing company.
Don't miss this Cisco Catalyst 8000 offer
Hello!   This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.    Virtual Assistant - Discover support content and options for your gearSupport page index - Contains a...
CoreyP319 by Cisco Employee
  • 4859 Views
  • 4 replies
I am not a tech personality and need a bit of hand holding in setting up my WAP4410N device. My old router Linksys 1500 seems to be having dropping signal issues and I purchased this WAP4410N online to replace it. I need to know if I made the right c...
tonyberru by Level 1
  • 479 Views
  • 2 replies
We are excited to announce the next phase of our initiative to relabel posts across the Small Business board. As part of this process, read-only mode will be activated on this discussion board from July 7th to August 15th. Please note that these date...
  • 378 Views
  • 0 replies
  • 1 Helpful votes
Cannot connect to brand new C1121X-8P with Putty for a serial session. No router prompt shows. Installed drivers, connected with USB to USB Micro cable but the light next to the console port doesn't light up. I have tried 4 different computers and wh...
wlee777 by Level 1
  • 310 Views
  • 5 replies
                  I want to configure my RVS4000 router but find that I am unable to login to the 192.168.1.1 site to do so. The "admin" username and password is not working. Maybe I do not have to as my internet connection seems to be working fine. ...
dare2tooo by Level 1
  • 219988 Views
  • 26 replies
Hope I'm in right place!I have a RV320 VPN Dual WAN router in my home office. I am having difficulty with configuration.I've tried the various wizards and setup options but am not able to get any internet access to PC's via the router.I can't seem to...
paulck by Level 1
  • 383 Views
  • 3 replies
HiI am unable to access my cisco RV320 router web ui login page after adding new self-signed certificate. It says 502 Bad Gateway. The self signed certificate was created using option in RV320 router's web ui.I added the new certificate because the b...
Hi all, I'm trying to understand how a device (or router) decides whether or not to respond to an ARP request, especially when there's a mismatch in subnet configurations between the sender and receiver. Consider the following setup: R1 – Gig 0/0/0 I...
Mar 16 20:24:48 2022 Kernel ipt_tcpmss_target: bad length (585 bytes)Mar 16 20:24:48 2022 Kernel ipt_tcpmss_target: bad length (585 bytes)Mar 16 18:44:10 2022 Kernel ipt_tcpmss_target: bad length (585 bytes)Mar 16 18:44:10 2022 Kernel ipt_tcpmss_targ...
ehosca by Level 1
  • 2661 Views
  • 11 replies
I have a IR829GW that was connected to a battery and the battery got drained. Now the Router wont boot up. It is stuck in a non boot up situation.There is no output on the console port and the LED's are stuck permanently on as shown in attached image...
kdennis by Level 1
  • 539 Views
  • 2 replies
Hello,I've a new RV042G V01 (I wondering why I get such a old device with Manufacturing Date 03/2014) Router and installed accidentally Firmware-Version v4.2.3.03 which is only working proper on Hardware version V3. Now I'm searching for the newest V...
