sh ver
Cisco IOS Software, C800 Software (C800-UNIVERSALK9-M), Version 15.4(3)M8, RELEASE SOFTWARE (fc3)
Technical Support:
http://www.cisco.com/techsupportCopyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Mon 31-Jul-17 06:05 by prod_rel_team
ROM: System Bootstrap, Version 15.4(3r)M1, RELEASE SOFTWARE (fc1)
BGT06120 uptime is 29 minutes
System image file is "flash:c800-universalk9-mz.SPA.154-3.M8.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.htmlIf you require further assistance please contact us by sending email to
export@cisco.com.
Cisco C881G-4G-GA-K9 (revision 1.0) with 887884K/29619K bytes of memory.
Processor board ID FGL204325JN
5 FastEthernet interfaces
2 terminal lines
1 Virtual Private Network (VPN) Module
1 Cellular interface
DRAM configuration is 32 bits wide
255K bytes of non-volatile configuration memory.
1000944K bytes of ATA System CompactFlash (Read/Write)
License Info:
License UDI:
Device# PID SN
*1 C881G-4G-GA-K9 FGL204325JN
License Information for 'c800'
License Level: advipservices Type: Default. No valid license found.
Next reboot license Level: advipservices
