Bookmark
Subscribe
633
Enable nbar2 on zone base firewall - cisco 881
shehanfernando
IOS version :- c880data-universalk9-mz.154-3.M4.bin
I'm looking to enable NBAR2 on cisco 881 router according to this doc . I couldn't find command called "nbar-classify" inside the following parameter-map command. Appreciate any feed back to fix this
(config)#parameter-map type inspect global
Philip D'Ath
You missed this important bit.
In Cisco IOS Release 15.5(1)T and later releases, zone-based firewalls supports Network-Based Application Recognition 2 (NBAR2).
Philip D'Ath
