I have an issue with the QOS setting / bandwith rate control.
I've tested it with a new factory config.
Setup : limit my IP (all ports) to max rate at 512 Kbit/sec (min rate to 1 Kbit/sec) in downstream and enable checked.
When I test my speed, there is no limit.
If it try the exact setup with a RVS4400 (without wireless) it works fine!!!
Does anyone have this issue or know how to solve it???
Thanks in advance
Al
Here is my setup... (and yes when I made sure I'm using 192.168.1.101 while doing the test...)
